February 28, 2021, 03:29:11 AM
Members
  • Total Members: 5894
  • Latest: list83
Stats
  • Total Topics: 12728
  • Online Today: 39
  • Online Ever: 78
  • (January 15, 2021, 06:24:24 AM)
Users Online
Users: 1
Guests: 22
Total: 23
Donations
Donations help with annual costs and keep Radarspotting free of advertising. Thank you.
Latest Post
Links & Files
21st February 2021. Latest Zip file from Chris Alder now available.
If you're looking for a bulk download, we have over 66,000 aircraft silhouettes, profiles and operator logos available in bmp file format, 85x20 pixels. You can find all the Zip files here.
Some of the Latest Additions:
Author Topic: Different colors depending on the sources  (Read 951 times)
Offline airvb
  • New Member
« on: January 07, 2019, 08:10:47 AM »
Bonjour, Hello,
I have 2 sources ( 1 raspberry + 1 very old eeepc )
Each one provide through dump1090-mutability, then fr24, raw data on port 30002.
Following this, i have an ubuntu server on which modesmixer2 is running with this command line :
Code: [Select]
/modesmixer2/modesmixer2 --web 8083  --inConnectId 192.168.1.154:30002:PI --inConnectId 192.168.1.102:30334:EEEPC --silhou
Like this i can see from which provider comes the information.
in this topic https://discussions.flightaware.com/t/how-to-get-vrs-like-coverage-map-on-rpi/31284?u=abcd567
It seems that it is possible too have differents colors on map depending sources ?
I tried without results
Any ideas ?
Thanks !
Offline Triple7
  • Member
Re: Different colors depending on the sources
« Reply #1 on: January 07, 2019, 03:57:43 PM »
My thoughts on this are you are perhaps overlooking the fact that Flight Aware return MLat calculated aircraft to you if you supply them your data. MSM2 is smart enough to know the difference between MLat and regular ADSB traffic and plots them in different colours. I suspect as you have not stated you are feeding Flight Aware, you are just seeing your own data.
Offline airvb
  • New Member
« Reply #2 on: January 08, 2019, 09:17:40 AM »
Thanks for yr prompt reply !
Maybe i haven't understand something.
I provide data to FR24, FlightAware
When i'm looking the map generating by dump1090 for my own data i can see on the list that there is some MLAT acf and adsb aircraft.
The MLAT acf are little bit shaded on the map.
Does it means MLAT acf positions are data coming from outside ?
Even this, how does the difference between MLAT and ADSB aircraft as describe in the above link ?
thanks.
Offline Anmer
  • Administrator
  • Top Poster
« Reply #3 on: January 08, 2019, 09:46:24 AM »
MLAT positions require a server processing data from a number of ground stations, with the data being processed on a server to calculate an MLAT plot.
Unless you're running an MLAT server, I suspect you're getting the MLAT traffic from the FlightAware server.
This MLAT explanation may help:
https://flightaware.com/adsb/mlat
Offline airvb
  • New Member
« Reply #4 on: January 15, 2019, 06:26:51 AM »
After differetns test , i found a solution.
Code: [Select]
daemon_OPT="--web 8083 --inConnectId 192.168.1.154:30002:PI --inConnectId 192.168.1.102:30002:EEEPC --inConnectId 192.168.1.154:30106:MLAT --inConnectId 192.168.1.102:30106:MLAT --silhouettes /
Like this MLAT's aircraft are shown in green color on the map,
The ADS one , white with the specification name  of the source !
thanks again for yr help !
