June 30, 2026, 03:41:18 AM
Operator Flags and Model Silhouettes does not seem
Started by lazspotter, July 04, 2019, 01:33:25 PM
lazspotter
Quote from: s92driver on July 05, 2019, 11:41:42 AM
Quote from: lazspotter on July 05, 2019, 10:42:31 AM
Quote from: Anmer on July 05, 2019, 10:41:00 AM
I give up.  :-\
Why?  :'(
You were asked to provide a screen capture like the one shown.  Your answer was simply "Thank you".   >:(
If you would like assistance you have to provide us with some images showing your settings, etc.
The system does work, so it must be how you have set it up that is at fault.  We have no idea what mistakes you have made if you don't provide screenshots.
I've added pictures as embed code. I guess the pictures don't show up.  I am so sorry
lazspotter
Quote from: Anmer on July 05, 2019, 10:32:31 AM
Where's the screen capture we requested?
There is something wrong with your setup.  We can help but you need to play your part too.
Can you post an image of your Virtual Radar Options window, similar to the attached.
i am sorry for the pictures...
Thank you, we see the images now.
See my attached images.  Can you view the BaseStation.sqb file in your folder path C:\Users\erdin\AppData\Local\VirtualRadar and check that for the aircraft records you have a corresponding OperatorFlagCode?
For example, for S7 Airlines VQ-BPN, does the hex code 424554 record in the BaseStation.sqb file have the OperatorFlagCode SBI, similar to the aircraft I have in my database?
lazspotter
Quote from: Anmer on July 05, 2019, 04:20:32 PM
My SQB file is out of date. But I found these.
Make sure you are checking the active BaseStation.sqb file in the folder path shown in the Virtual Radar Options.  You can "test" by making some edits for aircraft that you're currently seeing in Virtual Radar Server.
lazspotter
Quote from: Anmer on July 05, 2019, 05:48:09 PM
Not work :(
What doesn't work?  What did you do?
See attached image.  I have highlighted ICAO "40636F".  I had this aircraft in my BaseStation.sqb file without an OperatorFlagCode.  I added "R44" to the OperatorFlagCode field.  I refreshed the database and the Virtual Radar web page.  Now the R44 silhouette appears.
Everything is working.  You must either be editing the wrong BaseStation.sqb file or the path(s) in Virtual Radar Server options may be wrong.
lazspotter
Quote from: Anmer on July 06, 2019, 06:55:53 PM
My SQB file is not wrong, but it is old. The picture paths in VRS are also correct. Where can I find the current SQB file?
Quote from: lazspotter on July 07, 2019, 10:20:36 AM
You don't need a new sqb file to get the operator flags and silhouettes to work.  Changing the sqb file won't solve the underlying problem,
If your file paths in Virtual Radar Server are correct and you have an OperatorFlagCode that matches a bmp file in your OperatorFlags folder, the logo or silhouette should display.
lazspotter
Quote from: Anmer on July 07, 2019, 10:35:06 AM
All picture names and picture paths are correct. It's all in the pictures above. All settings are correct, but the pictures do not appear stubbornly.
And can you help me find the latest BaseStation.sqb file?
Do you have BaseStation Reporter?
If you do, please post a screen capture of your database records in yiur current sqb file, similar to the attached.
lazspotter
Quote from: Anmer on July 07, 2019, 12:56:26 PM
Yes, i have. (I downloaded it from this website, but this is old file: http://www.kinetic.co.uk/resourcesdownloads.php#4)
Do you want mew to make a remote connection to your PC and take a look with you?  I think the sqb path may be wrong.
lazspotter
Quote from: Anmer on July 07, 2019, 01:30:54 PM
Yeah, sure. But I don't know much English. Translate will be open.
We can manage with Google Translate.  See this thread:
https://radarspotting.com/forum/index.php/topic,9421.msg42189.html#msg42189
I will need to know the ID and Key.
Send this to me in a Personal Message.
