July 26, 2026, 12:25:08 AM
Operator Flags and Model Silhouettes does not seem
Started by lazspotter, July 04, 2019, 01:33:25 PM
lazspotter
Hello there;
I did all the setup correctly. As shown in the pictures. But the pictures don't show up. Can you help me?
May the force be with you...
What application are you using?
What have you "setup" and what "pictures" are you viewing?
This may help:
Please get back for more help if it's needed.
lazspotter
Quote from: Anmer on July 04, 2019, 02:48:01 PM
This may help:
Virtual Radar Server with kinetic. I downloaded the related pictures from this site. (Complies with ICAO codes.) All settings of the software are correct.
Have you added a corresponding OperatorFlag code to your aircraft records in the BaseStation.sqb database?
See my Guide.
lazspotter
Quote from: Anmer on July 04, 2019, 04:58:47 PM
See my Guide.
Yeah, it's in the database. But it still doesn't work.
Can you post a screen capture of what you're viewing?
Ospreyv22
HI,
I hope im not going to confuse this matter, but do you have the Countries.dat file in your programme,
and also as Anmer has said  make sure that the operator flag code like BAW for British Airways is exactly  spelt the same in your sqb.
I screen shot would help if you could.
Hope im not jumping and confusing things.
lazspotter
Quote from: Anmer on July 04, 2019, 10:14:17 PM
hi, it is.
Quote from: Ospreyv22 on July 04, 2019, 10:29:36 PM
HI,
What am I supposed to do with this?
We want to help but we need more information.
Please post a screen capture of where you expect to see the Operator Flags or silhouttes displayed.
lazspotter
Quote from: Anmer on July 05, 2019, 09:53:28 AM
I want to see it here. (Virtual Radar Server)
Where's the screen capture we requested?
There is something wrong with your setup.  We can help but you need to play your part too.
Can you post an image of your Virtual Radar Options window, similar to the attached.
lazspotter
Quote from: Anmer on July 05, 2019, 10:32:31 AM
Thank you,
s92driver
Quote from: lazspotter on July 05, 2019, 10:42:31 AM
Quote from: Anmer on July 05, 2019, 10:41:00 AM
I give up.  :-\
Why?  :'(
You were asked to provide a screen capture like the one shown.  Your answer was simply "Thank you".   >:(
If you would like assistance you have to provide us with some images showing your settings, etc.
The system does work, so it must be how you have set it up that is at fault.  We have no idea what mistakes you have made if you don't provide screenshots.
