November 28, 2026, 12:34:48 AM
PlanePlotter 6.4.8.8 Released
Started by Triple7, July 21, 2019, 03:44:38 PM
From Bev,
PlanePlotter version 6.4.8.8 is on the web site today.
---Usual boilerplate---
New in version 6.4.8.8
Longstanding bug fixed
For a long time, there has been a propensity for shared aircraft to make the occasional small jump backwards on the chart.  This tended to occur near the boundary of coverage where locally received aircraft were in the process of being replaced by shared aircraft.  It was caused by a position report incorrectly having its time tag updated when the position itself had not been updated.  This version fixes that phenomenon.
Obviously the 'jumping plots' will only disappear completely when all users are on the latest version.  Apart from the cosmetic effects, this may also have affected the quality of Mlats, especially where an aircraft was at the limit of coverage of Ground Stations.  For that reason, I would strongly urge all Ground Stations to adopt the latest version as soon as possible.  Thank you.
User defined timeout on automatic chart repainting
The option to repaint a chart or outline when it has been zoomed or dragged, has hitherto had a fixed timeout of 5 seconds after which the repaint would occur (if enabled).
At a user's request, that time is now user defined by selecting  Options..Chart..Auto chart refresh..Set timeout.  The Enable for the feature is now one level down at Options..Chart..Auto chart refresh..Enable.
Bev
COAA
