November 25, 2026, 09:22:11 PM
Airport naming set up-
Started by Graham Bell, July 04, 2012, 11:45:57 AM
Graham Bell
In the BaseStation radar screen is it possible to disable the ICAO code on the airport names thereby showing the geographical location only?
Regards-
G.B.
Names on the map are Waypoints.  One can edit a waypoint file using Notepad or other text editor.
Here's an extract from my UnitedKingdon.wpt file:
Humberside,,2,1,53.57446944,-0.350741667,121
MARGO,,1,2,54.7075,-2.77472,0
Sibson,,15,1,52.55583333,-0.386388889,26
Coventry,,2,1,52.36981,-1.47968,281
This is what Sibson would look like if I wanted to show only the geographical location as "52.55/-0.38":
52.55/-0.38,,15,1,52.55583333,-0.386388889,26
Not sure why one would do that but have a read of Bones' Tutorial and the section T3.2 Outlines:
Usual health warning applies about backing up files before editing.
http://www.homepages.mcb.net/bones/SBS/Article/Barebones.htm
acarslogger
Graham -- not exactly sure what you mean by "geographical location only", but you don't need any name/title on a waypoint.
The location of Sibson would simply show as a waypoint without any text if you use
Stuart
Graham Bell
Thanks for the response,to clarify my wants what I would like to achieve is the airfield/airports location to appear as Southampton NOT Southampton EGHI.
Are the two posts still relevant?
Regards-
G.B.
Thanks for the clarification Graham.
In my example, replace the section in bold ("52.55/-0.38") with the name you want to display.
I suggested reading Bones' Tutorial because he clearly explains the construction of a waypoint line in the wpt file.
The first element (before the comma) is the name that will appear on the map.
Graham Bell
Mike-
I am obliged to you.
Regards-
G.B.
