November 26, 2026, 03:17:56 PM
SBS 1 not responding
Started by chimney1, September 28, 2019, 11:44:38 PM
chimney1
I came to switch on my SBS1 this evening after many years of using.The screen was without any columns or map display , so i decided to uninstall and do a new install , i have managed to create a screen but i cannot install drivers, i am using the original CD of Kinetic any help would  be welcome  Chimney1
Try downloading the up to date software from here. http://kinetic.co.uk/basestationdownloads1.php#
Check the firmware options also
How is your SBS connected to your PC?  USB or Ethernet cable>
Do you see any blue lights at the front of the SBS?
When you launch the reinstalled version of BaseStation do you get any error messages?
Close BaseStation.
In your BaseStation folder, you should find a file
SBS1LinkTester.exe
Double click this to run the application.  DWhat result do you get?
With BaseStation still closed find this file in the same folder:
CDM20814_Setup.exe
Double click this for it to run.
Then relaunch BaseStation.
Is the screen still devoid of aircraft?
chimney1
Good Morning all  i have just turned on my SBS1 on i have the 2 first lights on and 3 blue lights are also showing ,my unit is connected by ethernet. I have looked for the SBS link  tester and CDM20814Set up but cannot find in folders- Chimney
Both files should be in your BaseStation folder.
chimney1
When i did the reinstall i used the original CD (2005) ,i am still unable to find these files in the basestation  folders ,i seem to have masses of operator flags and xml files -Chimney 1
What I'd suggest is the same as mhm.
Download the latest CD file and make a fresh install of the latest BaseStation version 184.
But do not accept the default install location.  Instead create a new folder called Kinetic and install there.
The other consideration is the IP address of the SBS may have changed?  Do you see it connected to your local network in your router admin?
chimney1
Gentlemen i am reconnected to my SBS1 thank you so much MHM and Anmer for sorting me out by suggesting installing the 184 version. Sunday afternoon is going to be pleasurable.
Best Regards Chimney1
Well done.  Great to hear you're back up and running.
Yes well done nice to here your back up and running.
I would advise anyone out there to download a copy of the files on the kinetic site, in case it goes down.
Quote from: mhm on September 29, 2019, 05:33:36 PM
I did that a few days ago, just in case.
Falcon200EX
Hi, As per this post my SBS1 has stopped working. When I open BS it continually shows Not Connected and no planes. I get 1 red light and 3 blue lights on the front of the SBS and I'm sure there should be more lights showing. I'm connected via Ethernet. I've tried all things mentioned and its still not working. The SBS1 Link tester shows fail, I've downloaded and installed version 184 but I get the radar with no planes. The version I have installed at present is 185. The only thing I haven't done is to check if it's connected to my local network in the router admin as I don't know how to do that.
Any help to resolve this problem would be much appreciated.
Thanks Mike
Just off to bed right now, will reply in full tomorrow.
Morning.
Has anything recently changed, like a Windows update?
How is the SBS-1 connected to your PC?  USB or Ethernet cable?
If it's by USB cable, try plugging it into a different USB port.
The following will depend on your version of Windows but you need to navigate to Device Manager.  Google how to do this for your Windows version.
In Device Manager, look for Universal Serial Bus Controllers and expand the list.
Do you see the Device A and Device B listed?
Also make sure your BaseStation -> Settings -> Data Source is set to "Use USB"
If you're using an Ethernet Cable, is the Data Source set to "Use Network"?
There will be other checks for Ethernet but let's first confirm what connection you're currently using.
One last question.  You say you're on BaseStation 185.  I didn't think there was a Version 185?
