November 29, 2026, 02:10:52 AM
PlanePlotter 6.4.9.1 Released
Started by Triple7, October 14, 2019, 02:21:48 PM
From Bev:
PlanePlotter version 6.4.9.1 is on the web site today.
---Usual boilerplate---
New in version 6.4.9.1
"New" aircraft
If you chose to alert or record aircraft that were "new" (when not in the SQB database), that action did not occur if there was no registration available. That is fixed in this release.
Auto centring
Previously the autocentring option in Options..Chart..Auto refresh and Options..Chart..Outline..Auto refresh only applied to manual movement of the chart or outline.  This version implements the option if you select Option..Chart..Options : Centre chart on designated aircraft.  This means that if you are tracking a designated flight, it will not "run off" the current chart or outline.  Watch this video to see the effect.  www.coaa.co.uk/PPautocentre.mp4
JAERO flight numbers
This version fixes a bug when a report delivered by JAERO lacks a flight number.
Beamfinder ping logging option
This version adds the option in the Beamfinder function to create a ping log for a specific identifier or pulse rate, rather than for all identifiers.  This may help processor load in locations/receivers with a very high message rate, which previously may have struggled to keep up with the logging of all identifiers and rates.
The analysis of the ping logs for Beamfinder now detects zero radials.
Condex setup
A new accelerator key (Alt-c) opens the conditional expressions setup dialog for chart displays.
Home location
A new accelerator key (Alt-h) opens the home location dialog.
Enjoy!
Bev
COAA
