April 22, 2026, 11:05:34 PM
A/C View window editing
Started by gcopter1, November 17, 2019, 03:02:21 AM
gcopter1
Is there a way to edit this window so that, columns can be deleted?
I find that some columns are of no use to me and clutter the view.
If you mean the floating Aircraft View window, you can't delete the columns, but you can re-order them. View>>Aircraft data window>>Setup data window layout allows you to specify the column order. I have mine setup and then I reduce the window size and "park" it to the side of my screen, that way I can see the plots and the data window - a bit like the BaseStation layout.
gcopter1
Thanks for that, Tim.
After your answer, I discovered that I was using that feature the "wrong" way.
I was clicking on the aircraft silhouette button, to look at that info.
I was overlooking pressing the small case letter "a" to float the window over the display.
I can now see the info I need in a more condensed way.
