October 14, 2026, 05:24:13 PM
Cannot install latest version
Started by hbervoets, July 08, 2012, 11:55:22 AM
hbervoets
I was trying to install the latest version of ActiveDisplay_1_64_4_2
Uninstalled previous version, when install (after unzipping downloaded file) did not worked, searched PC for remaining Active Display files and permanently deleted them.
Uninstalled Microsoft .Net framework 4 and reinstalled after several "Windows Update"'s.
Running Windows 7 64 bit
This is the error message received :
PLATFORM VERSION INFO
   Windows          : 6.1.7601.65536 (Win32NT)
   Common Language Runtime    : 4.0.30319.269
   System.Deployment.dll       : 4.0.30319.1 (RTMRel.030319-0100)
   clr.dll          : 4.0.30319.269 (RTMGDR.030319-2600)
   dfdll.dll          : 4.0.30319.1 (RTMRel.030319-0100)
   dfshim.dll          : 4.0.31106.0 (Main.031106-0000)
SOURCES
   Deployment url         : file:///C:/Program%20Files%20(x86)/Kinetic/ActiveDisplay/ActiveDisplay.application
   Application url         : file:///C:/Program%20Files%20(x86)/Kinetic/ActiveDisplay/ActiveDisplay_1_64_4_2/ActiveDisplay.exe.manifest
IDENTITIES
   Deployment Identity      : ActiveDisplay.application, Version=1.64.4.2, Culture=neutral, PublicKeyToken=a787c7e0a78e97c7, processorArchitecture=msil
   Application Identity      : ActiveDisplay.exe, Version=1.64.4.2, Culture=neutral, PublicKeyToken=a787c7e0a78e97c7, processorArchitecture=msil, type=win32
APPLICATION SUMMARY
   * Installable application.
ERROR SUMMARY
   Below is a summary of the errors, details of these errors are listed later in the log.
   * Activation of C:\Program Files (x86)\Kinetic\ActiveDisplay\ActiveDisplay.application resulted in exception. Following failure messages were detected:
      + Store metadata "DeploymentProviderUri" is not valid.
COMPONENT STORE TRANSACTION FAILURE SUMMARY
   No transaction error was detected.
WARNINGS
   There were no warnings during this operation.
OPERATION PROGRESS STATUS
   * [8/07/2012 10:54:49] : Activation of C:\Program Files (x86)\Kinetic\ActiveDisplay\ActiveDisplay.application has started.
   * [8/07/2012 10:54:49] : Processing of deployment manifest has successfully completed.
   * [8/07/2012 10:54:49] : Installation of the application has started.
   * [8/07/2012 10:54:49] : Processing of application manifest has successfully completed.
   * [8/07/2012 10:54:56] : Found compatible runtime version 2.0.50727.
   * [8/07/2012 10:54:56] : Detecting dependent assembly Sentinel.v3.5Client, Version=3.5.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a, processorArchitecture=msil using Sentinel.v3.5Client, Version=3.5.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a, processorArchitecture=msil.
   * [8/07/2012 10:54:56] : Detecting dependent assembly System.Data.Entity, Version=3.5.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089, processorArchitecture=msil using System.Data.Entity, Version=3.5.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089, processorArchitecture=msil.
   * [8/07/2012 10:54:56] : Request of trust and detection of platform is complete.
   * [8/07/2012 10:54:57] : Downloading of subscription dependencies is complete.
   * [8/07/2012 10:54:57] : Commit of the downloaded application has started.
ERROR DETAILS
   Following errors were detected during this operation.
   * [8/07/2012 10:54:57] System.Deployment.Application.DeploymentException (SubscriptionState)
      - Store metadata "DeploymentProviderUri" is not valid.
      - Source: System.Deployment
      - Stack trace:
         at System.Deployment.Application.ComponentStore.GetPropertyString(DefinitionAppId appId, String propName)
         at System.Deployment.Application.ComponentStore.GetPropertyUri(DefinitionAppId appId, String propName)
         at System.Deployment.Application.ComponentStore.GetSubscriptionStateInternal(DefinitionIdentity subId)
         at System.Deployment.Application.SubscriptionStore.GetSubscriptionStateInternal(SubscriptionState subState)
         at System.Deployment.Application.SubscriptionState.Validate()
         at System.Deployment.Application.ComponentStore.CollectCrossGroupApplications(Uri codebaseUri, DefinitionIdentity deploymentIdentity, Boolean& identityGroupFound, Boolean& locationGroupFound, String& identityGroupProductName)
         at System.Deployment.Application.SubscriptionStore.CommitApplication(SubscriptionState& subState, CommitApplicationParams commitParams)
         at System.Deployment.Application.ApplicationActivator.InstallApplication(SubscriptionState& subState, ActivationDescription actDesc)
         at System.Deployment.Application.ApplicationActivator.PerformDeploymentActivation(Uri activationUri, Boolean isShortcut, String textualSubId, String deploymentProviderUrlFromExtension, BrowserSettings browserSettings, String& errorPageUrl)
         at System.Deployment.Application.ApplicationActivator.ActivateDeploymentWorker(Object state)
COMPONENT STORE TRANSACTION DETAILS
   No transaction information is available.
I assume the uninstall was via Program Files?
There may be some registry entries hanging around.
I suggest you post this on the Kinetic Forum as Gary from Gatwick Aviation Society will read it and respond.
hbervoets
Thanks Anmer,
Yes uninstalled via Control Panel : uninstall pgm.
will contact Gary
