April 22, 2026, 07:08:10 PM
PlanePlotter 6.4.9.4 Released
Started by Triple7, January 23, 2020, 08:00:14 AM
From Bev
PlanePlotter version 6.4.9.4 is on the web site now.
---Usual boilerplate---
New in version 6.4.9.4
The Auto refresh map/chart feature now operates if the map is moved by local GPS input updating the "home location" when "Centre chart on home location" is enabled in Options..Chart..Options.
Note that the default refresh time is 5 seconds, intended to be the time after dragging the map/outline using the cursor, that the chart will be refreshed.
If the movement is provoked by a GPS in a moving vehicle, then fifteen minutes might be a more reasonable refresh time to avoid the program continuously downloading a new map every five seconds, which would probably freeze PlanePlotter.
Please don't use this feature if you are a validated Ground Station.  The server sends us an email alert if the location of a validated Ground Station changes. That could be a lot of emails if you are travelling with the system running.
There are eight new user-selectable options under Options..Fonts and colours..Chart annotation colours.
These options allow you to select the colours used for the boundary of an alert zone, the ring around an aircraft triggering an alert, the ring around the designated aircraft, the ring around the aircraft specified for the simulated flight deck view, the boundary of a user-defined frequency zone, the concentric rings around an aircraft that triggers an "ident", the ring (not currently implemented) around an aircraft defined as interested, and the optional range rings.
Enjoy!
Bev
COAA
