September 23, 2026, 01:27:56 AM
Flightradar24.com
Started by TEDDYBEAR, July 12, 2012, 12:06:52 PM
TEDDYBEAR
On checking aircraft flights for yesterday I have noticed that no data has been shown.
Can anyone tell me if this is a fault or has something changed. It shows the present flight which directs you to flightradar24 but nothing else.
Bryan
Just tried Playback for yesterday, 08:00 UTC and no flights are showing.
Then I remembered seeing a post on the FR24 forum (which I didn't read) but have found:
"We had a problem with the server yesterday and have no data saved from 15:25 UTC and it looks like the data is still not being saved now @ 12:50 UTC, so there must be a problem with the server.
Playback before yesterday @ 15:25 is working.
Mike / Speedbird"
TEDDYBEAR
Thanks for the quick reply Anmer
Bryan
John1958
Hi guys, looking on FR24, and looking at the USA, there are wild "hex" codes on there. If I took my SBS and ran ADLite while over there, would it pick up the correct hex/registration/serial for any aircraft I might see?
John
John
Some of the FR24 USA data comes from the FAA (orange aircraft) without a hex code.  If FR24 can't match the aircraft to a known hex code it will use a false one.
If you take a Mode-S receiver to the USA and ran AD Lite, it will work fine as the FAA non-hex data wouldn't be received.
John1958
Hi ANMER.......cheers for that!!!!!
John
