November 27, 2026, 11:30:41 PM
High quality data cable
Started by Pipo, April 22, 2020, 03:08:40 PM
Thanks for the update.  It's good to know it works for you.
ChiperHead007
It might be a broken/loose Soilder joint actually on the rear of the SBS box.  Do not wiggle the USB port too much but if you just gently move the USB Port and you see some play that may be the reason.
Also if you have a faulty Power supply if its a Desktop PC this can cause it by not giving out enough umph to your box.
You can have a Desktop that works ok and it still can have a faulty PSU where usually the 5V rail has fails.
Steven
Thanks Steven.
Pipo replaced the USB cable and that resolved the issue.
Pipo
Quote from: ChiperHead007 on December 04, 2020, 10:59:47 PM
Steven
Since i replace it with the new usb cable it is working great again, no los of connection since then, and the distance betwin pc en sbs-1e is 1mtr.
Uniden UBC125XLT
