November 27, 2026, 11:30:41 PM
High quality data cable
Started by Pipo, April 22, 2020, 03:08:40 PM
Pipo
Hello all, im thinking about buying a high quality data cable (gold plated) for my sbs-1e. Any here that is using a high quility data cable?
https://theshortener.com/ze
Uniden UBC125XLT
I don't think a different USB cable will make any improvement.  Why are you thinking of getting one?
Pipo
Quote from: Anmer on April 22, 2020, 03:26:12 PM
I think my OEM cable has a broken wire inside, when i move the cable sbs-1e is losing connection
Uniden UBC125XLT
Pipo
Sp you don't think a gold plated cable will give beter data transfer to my pc? So if i order a new cable i can stick with a standard 2mtr cable?
Uniden UBC125XLT
I think a standard USB cable will be just as good as a "gold-plated" one.
Pipo
Quote from: Anmer on April 22, 2020, 03:46:29 PM
So for communictation betwin pc and sbs-1e a normal data cable (max 2mtr) is oke to use?
Uniden UBC125XLT
As long as you have the right connectors, you should be good.
I swap around and grab whatever USB cable is available.  Never had an issue.
jakems
USB is used to carry digital data, so in theory if the data is corrupted the protocol should detect it and retransmit it. The gold plated connectors were much more important when the data transmission was analog and a poor connector could corrupt the data. I have always bought the cheapest USB cables and have not had any issues. I am not a hardware specialist but this is how I understand it works.
Steve
Thanks Steve, good explanation.
Pipo
Quote from: Anmer on April 22, 2020, 07:21:53 PM
Anmer,
What is the maximum lenght of the usb cable i can use to connect to Basestation? Im thinking about buying this one:
https://www.aliexpress.com/item/33032571476.html?spm=a2g0s.8937460.0.0.39552e0eYdnDWv and then the 3mtr one. Faramir told me this cable has less interference. I dont want to connect my sbs-1e with LAN and when im going to put new antenna on teh roof i want to make a shelf behind my computer chair and this is around 2.5/3mtrs away from my USB port in my desktop pc.
Uniden UBC125XLT
I'm not aware of a maximum length specified for an SBS but normally 5 metres is considered the limit for USB 2 cables and 3 metres for USB 3.
One can use longer "active" USB extension cables that amplify the signal.
Pipo
Quote from: Anmer on August 27, 2020, 07:16:40 PM
Without using a extender, i can use the one i showed that i can buy on aliexpress?
Uniden UBC125XLT
Quote from: Pipo on August 28, 2020, 10:56:26 AM
I can't ofrfer any advice about the caBLE BUT IF IT'S ONLY 3 METRES LONG, IT
I have a FlightAware ProStick in the loft and recently bought this 10m USB lead to get it connected to my PC downstairs:
https://www.amazon.co.uk/gp/product/B011RCUH1G/ref=ppx_od_dt_b_asin_title_s00?ie=UTF8&psc=1
I know this isn't specifically what you were asking but thought it might be useful info for someone.
I'm not recommending this cable over any others, it is just the one I bought and it works OK for me.
I used a different 10m USB repeater cable for several (5 or 6) years but it became unreliable hence the recent purchase of this one as a replacement.
Keef.
Pipo
Today i got the mail from aliexpress with a 3mtr usb cable for my sbs-1e, good quality and did a link test, it is working great. Now my sbs-1e can stand next to my scanner. Next week hope to build adsb antenna on my roof.
Uniden UBC125XLT
