May 03, 2026, 10:16:11 AM
difference betwin rg cables
Started by Pipo, August 05, 2020, 12:45:37 PM
Pipo
Uniden UBC125XLT
Pipo
Uniden UBC125XLT
Pipo
Quote from: Anmer on August 05, 2020, 02:11:10 PM
I bought pigtail cables oFf ebay.  Like this:
https://www.ebay.co.uk/itm/50cm-Cable-BNC-Male-Plug-To-SMA-Male-Straight-Crimp-RG316-20in-Jumper-Pigtail/283969406813?hash=item421de5475d:g:MGIAAOSwxoxfKndH
You can get shorter lengths and different connectors.  The cable is so short, you don't need to worry about signal loss.
The pigtails have thin cable and are very flexible, like the third one in your list:
https://nl.aliexpress.com/item/33030793429.html?spm=a2g0o.productlist.0.0.498b2bd7QR7QzH&algo_pvid=29d6d1f8-2a7f-44ce-9231-06a5a99c1786&algo_expid=29d6d1f8-2a7f-44ce-9231-06a5a99c1786-2&btsid=0b0a3f8115966278482898793ef463&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
Anmer, i had sent a scanner / radio shop a email if they have the cable (before i order the one at aliexpress) today i got a email. I ask them for a 30cm cable with a BNC male and SMA male connector, that people have a shop and want to make some money oké but 65 euro ex taxes for a cable. This is the email:
We don't have such ready-made cables, but I could make one.
This with RG198 coax cable because an SMA cannot be soldered to an RG58, in addition, the RG198 is too thin for a BNC, but we can solve this by means of aluminum foil with which we thicken the outer jacket.
With a shrink tube around it, this will also look like a commercial cable.
If interested, I will make it for 65 Euro (ex. VAT)
Uniden UBC125XLT
I suspect RG 198 is similar to Ecoflex 15.  15mm diameter, low loss and expensive cable.
Why would you want 30cm of this cable?
QuoteI ask them for a 30cm cable with a BNC male and SMA male connector,
Pipo
Quote from: Anmer on August 06, 2020, 06:50:51 PM
My plan is to make a wood board in corner of my computer room and fit the sbs-1 with L brackets and next to it the BC-12 and dont want to BC-12 to be close to my sbs-1, this due to the max length of antenna cable, so 30cm was the max what i would lik. Aliexpress is order 12inch rg316 cable
Uniden UBC125XLT
Pipo
and also the 30 cm that i have a little bit of movement when changing my computer room, when we maybe going to move to Belgium.
Uniden UBC125XLT
Faramir
Quote from: Pipo on August 05, 2020, 06:19:06 PM
i just ordered this one https://nl.aliexpress.com/item/33030793429.html?spm=a2g0o.productlist.0.0.498b2bd7QR7QzH&algo_pvid=29d6d1f8-2a7f-44ce-9231-06a5a99c1786&algo_expid=29d6d1f8-2a7f-44ce-9231-06a5a99c1786-2&btsid=0b0a3f8115966278482898793ef463&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
See if it works before i put everything on my roof, if not i maybe have to ask internet radio shops to make a cable for me.
No worries, connecters are ordered for Aircell-7 BNC to SMA. Costs less than 10 euro's...
I'm dissapointed that my pigtale was modified. I think I owe you that pigtail so you have an operational set!
Pipo
Quote from: Faramir on August 06, 2020, 08:39:31 PM
No problem Faramir, im happy to have this antenna for a good price, and i can wait for the pigtail from aliexpress, delivery around 20aug-8sept
Uniden UBC125XLT
