August 27, 2026, 12:36:07 AM
NEW HEX A4B241
Started by TEBBIZ, August 12, 2020, 05:22:15 PM
TEBBIZ
Afternoon all, N121RS GLEX C/N 9203 has been re-registerd N401VP HEX A4B241 winging IAD - SFM  as TWY22
CHeers - Seymour
Oblivian
A handy tool for your other queries to lookup what reg they should be allocated to.
http://www.avionictools.com/icao.php
US reg/HEX are pre-allocated so able to be worked out as the 'N' is a conversion from 'A' in binary. US range starts at A00000. A00001 = N1 :)
(except where owners reserve a 'special' one and can sometimes not be in sync with HEX they are programmed to)
Airframes.org must be using the same hex to reg formula.
It doesn't have A4B241 in its database but returns the "converted" reg.
Oblivian
Yep. I've not yet added similar to my own reg v country check. Canada is worked out similar I think
Conversion can help look at the suspected case with faa, to find the status. Although pending changes can be delayed
reg without the n to the end of the url
https://registry.faa.gov/aircraftinquiry/NNum_Results.aspx?NNumbertxt=401VP
shows reserved. (Which think can indicate it may also be able to operate with that hex. But a different registration than expected)
While the original shows changes pending
https://registry.faa.gov/aircraftinquiry/NNum_Results.aspx?NNumbertxt=121rs
