May 02, 2026, 10:04:24 PM
Countries Dat File
Started by G-PHIL, February 03, 2021, 02:04:37 PM
G-PHIL
Some op flags are not populating on my screen.
Has anyone got an upto date dat file, to see if it helps me out?
MTIA
Phil
Quote from: G-PHIL on February 03, 2021, 02:04:37 PM
The Countries.dat file has no influence over Operator Flags.
Can you be more specific about what you're experiencing?
G-PHIL
Anmer,
Not all the operator flags are populating the column and some country flags are not showing either.
Phil
Thanks Phil
If Operator Flags aren't appearing, check the aircraft record has a valid Operator Flag Code and you have a matching bmp file.
https://radarspotting.com/forum/index.php?action=tportal;sa=download;dl=item43
For Country Flags, no one person has been maintaining the Countries.dat file and mine may not have an entry for the relevant hex code.
You're better off maintaining your own dat file:
https://radarspotting.com/forum/index.php?topic=7159.0
G-PHIL
Hi Anmer,
Thanks for replying. It's the basic aircraft like Ryanair, Loganair, Aeromexico that haven't been showing upto now.
Could you send me your file to try if you don't mind, it's worth a shot.
Phil
Quote from: G-PHIL on February 03, 2021, 03:48:09 PM
Do you mean country flags or operator logos not showing?
I've emailed you a copy.
G-PHIL
Anmer,
Thanks, I've copied it over and will let you know what happens. I just need some aircraft now lol.
Phil
G-PHIL
Anmer,
Seems to be a bit better, but there aren't many planes over me at the moment.
I had a Thomson B787 over me but the country flag didn't show.
Phil
Quote from: G-PHIL on February 03, 2021, 04:26:57 PM
What was the hex code for the aircraft and were you using my dat file?
G-PHIL
Anmer,
No, I was using mine. I have reinstalled new Operator Flags and the Country Flags and all seems to be working at the moment.
I'll let things run for a while and see what happens and if I have any more issues I'll let you know.
Thanks for your help so far.
Phil
