June 24, 2026, 12:24:34 PM
USB Stick Mode-S Receiver
Started by Anmer, February 05, 2012, 02:06:05 PM
Thanks to member Jodel for pointing out this new Mode-S receiver.
USB stick sized and works with PlanePlotter and ADS-B Scope.
Transair are selling this for GBP £159 and it comes with an antenna.
More info here:
http://www.gns-gmbh.com/index.php?id=219&L=1
http://youtu.be/FXF2IeKi_-8
http://youtu.be/E6_pws75zec
May I add my thanks to Jodel for this interesting demo.
Hamish McTorsk
kendl
Looks ideal for using out and about. Unfortunately my lappy hasn't a pentuim 4 :(
Quote from: kendl on February 17, 2012, 02:08:10 PM
Is that a minimum spec for this receiver?
kendl
According to the transair site
System requirements: Windows 2000/XP/Vista/Windows7, USB 2.0 Port, Pentium 4, 512 MB RAM, VGA Graphics card.
Does seem a bit ott.
I don't think Transair has got that right.
This is what the GNS-GMBH says:
usable on Notebook, PC or tablet PC
It's only a receiver and if your PC can run PlanePlotter or ADS-B Scope it should work fine.
kendl
Yes I read that. I am beginning to wonder if Transair are erring on the side of caution for some reason.
Bethsalem
I'm open to be corrected by someone more knowledgeable than me, but isn't the gubbins of this receiver Miro's microADSB usb stick?
At more than double the price does it offer any advantages over the microADSB?
kendl
How does the microADSB usb stick compare to the Radar Box?
Quote from: Bethsalem on February 17, 2012, 07:28:39 PM
Add margin and distribution costs and a price soon doubles.
The company name 'Global Navigation Systems' has stirred some memories for me. When 32 Sqn RAF at Northolt got the new BAe HS125 700 series they were fitted with a navigation system called GNS made by Global Navigation Systems, a US based company. The system worked on reception of 25Khz carrier wave, typically used for base to submarine working. It had a sun seeking antenna and a rubidium atomic clock. When we got the first one we were amazed to find that inside the hangar, with steel doors shut, we could pick up a fairly strong signal from a submarine communications station in Australia.
Bethsalem
Quote from: kendl on February 18, 2012, 07:44:20 AM
I only use the indoor antennas provided with both the RadarBox and the microADSB and I would say that the microADSB stick picks up about half the contacts of the Radarbox.
However, I subscribe to PlanePlotter's network which then levels the playing field as I have other sharers to the north and south of me who fill in any holes I have, as I'm really only interested in local traffic.
For the money it costs, I think the microADSB stick is a pretty good deal if combined with the PlanePlotter network, and Miro is an excellent guy to deal with.
Stephen
kendl
Thanks for the info Stephen. As my SBS is set up in the attic I am really looking for something to take when on holiday so range isn't too much of a priority.
Bethsalem
Then the microADSB would certainly be a good choice if you just want an inexpensive, small form, mobile receiver.
It does suffer from the "doughnut effect" a bit though, in that aircraft at closer range can disappear then reappear, but the latest version of the firmware (version 9) makes an attempt at solving this.
Stephen
