October 14, 2026, 05:41:02 PM
Deleting Mode-S codes
Started by AlanT, May 12, 2021, 07:08:58 AM
AlanT
Gents
Is there any way of deleting mode-s codes en-block for redundant airframes, thinking of the likes of RAF Harriers, tornadoeos, tristars etc etc, rather than have to felete each one individually.
I do not have much computer knowledge so anything technical is probably out of my comfort zone.
Alan
reheat101
Morning Alan,
Sounds like you have a pretty old SQB there ?,
I'm pretty sure you cannot do a bulk delete of mode-s code's in Basestation Reporter, or any other populating software, I could be wrong,
maybe check out Planebase.biz,
Why not start fresh with s92driver's SQB which you can download from here along with corresponding operator logos.
Lee.
SBS-1 Populate has the option to bulk delete aircraft types.
Alternatively you can use an SQL editor such as SQLite Expert Personal.  SBS-1 Populate looks to be the easier option which you can download using the link in this post:
https://radarspotting.com/forum/index.php?topic=12732.msg52335#msg52335:
egnx
Be aware that you can only remove a mode-s code that doesn't have any existing associated Flights in the BaseStation.sqb
So if the mode-s you want to delete has associated flights those have to be removed from the Flights table first before the Aircraft record can be deleted.
I don't know what the SBS-1 Populate does in these circumstances ?
egnx
Quote from: egnx on May 12, 2021, 09:25:17 AM
It deletes the associated sessions too.
Just, successfully, deleted all TOR types.
AlanT
Thanks gents will give SBS-1 Populate a try
Alan
