November 23, 2026, 03:05:55 AM
Military aircrafts
Started by ishaimiev, May 16, 2021, 07:07:04 PM
ishaimiev
Quote from: Anmer on May 25, 2021, 08:35:24 AM
How do you launch VRS?  Do you have a Desktop shortcut?
If you do, right click on the Desktop icon for VRS and select Properties.  What is shown under "Target"?
Thank you.
Try saving the localaircraft.txt file in the folder:
C:\VirtualRadar
ishaimiev
Thank you . Check it out this week
Starting with version 2 of Virtual Radar Server you can override the IsMilitary flag in the standing data database for individual ICAOs.
To do this you have to create a file called LocalAircraft.txt in Virtual Radar Server's configuration folder (to get to the configuration folder go to Help | About and click the link to the configuration folder there).
http://www.virtualradarserver.co.uk/flightroutes.aspx
ishaimiev
How many aircraft can i add to the localaircraft file? I have 50,000 military aircraft
Quote from: ishaimiev on May 25, 2021, 01:33:52 PM
Surely the LocalAircraft.txt file is only used to override the designation in the StandingData.sqb file?  You don't need to add 50,000 records to the LocalAircraft.txt file?
You may get more help on the VRS Forum?
https://forum.virtualradarserver.co.uk/
gunterb
In the screenshot of the directory (AppData\Local\VirtualRadar) the file LocalAircraft.txt has the date 18.05.2021.
The StandingData.sqb file has the date 08.05.2021. This is not OK. The file StandingData.sqb is actually updated automatically every day. This is obviously not the case with you. Thats strange.
ishaimiev
The photo was sent by the old one. From the post on May 18
