November 23, 2026, 03:05:54 AM
how to edit standingdata.sqb virtual radar server?
Started by ishaimiev, May 25, 2021, 11:59:36 AM
ishaimiev
how to edit standingdata.sqb virtual radar server. Documentation http://www.virtualradarserver.co.uk/flightroutes.aspx
It is not clear how to edit military aircraft.
You will need an SQL editor, such as SQLite Expert Personal.
What data do you want to edit?
Always take a copy of any file before you edit in case you need to revert.
ishaimiev
I want to change military aircraft and add new ones.
In the IsMilitary column, the value is 1/0, what is it? Yes or no?
Quote from: ishaimiev on May 25, 2021, 01:29:38 PM
Without knowing the aircraft record I can't answer the question.  Change one a see what it does?
s92driver
There is no point amending this file as a new version will be automatically downloaded on a daily basis, overwriting any changes you introduce.
ishaimiev
I want to work offline, so there will be no amendments.
