November 27, 2026, 11:12:43 PM
Base Station no longer showing icons
Started by skywarrior, June 16, 2021, 04:30:53 PM
Java may not be installed correctly?
Can you Zip all your OperatorFlags files and email it to me?
skywarrior
skywarrior
skywarrior
What is your email address as I tried to send the zip file through Radarspotting, but I believe it is to big
skywarrior
OK, zip file is finally on its way.  Hopefully you spot a rouge file!
Thanks again
Bruce
Quote from: skywarrior on June 23, 2021, 12:26:22 AM
Zip received, extracted and checked with BMPChk.  You have quite a few "rogue" files. From where did you get them?
BmpChk V2.0
Checking bmp files in I:/LCN Websites/Radarspotting/logos2
Dimension 85 x 25 for file 1346.bmp is unusual
Dimension 85 x 26 for file AACHARTER.bmp is unusual
Dimension 85 x 24 for file ACA190.bmp is unusual
Dimension 85 x 25 for file ACC.bmp is unusual
Dimension 85 x 22 for file AcropolisAvA318.bmp is unusual
Dimension 86 x 19 for file ADA.bmp is unusual
Dimension 85 x 25 for file AERCAP.bmp is unusual
Dimension 87 x 25 for file aerojeT.bmp is unusual
Dimension 85 x 24 for file AIRCASTLE.bmp is unusual
Dimension 85 x 25 for file AIRDO.bmp is unusual
Dimension 21760 x 0 for file ARG738.bmp is unusual
Dimension 85 x 25 for file AVELO.bmp is unusual
Dimension 85 x 24 for file AVJET.bmp is unusual
Dimension 60 x 54 for file AZGAME.bmp is unusual
Dimension 85 x 24 for file AZSU.bmp is unusual
Dimension 85 x 25 for file BAM.bmp is unusual
Dimension 85 x 25 for file BancOFMex.bmp is unusual
Dimension 85 x 25 for file BE3.bmp is unusual
Dimension 78 x 20 for file BE55.bmp is unusual
Dimension 87 x 26 for file bristell.bmp is unusual
Dimension 80 x 20 for file C-FMFN.bmp is unusual
Dimension 85 x 38 for file C45H.bmp is unusual
Dimension 66 x 20 for file CareFltBE20.bmp is unusual
Dimension 88 x 20 for file Cargill.bmp is unusual
Dimension 85 x 24 for file CASS_1.bmp is unusual
Dimension 85 x 25 for file Colombia.bmp is unusual
Dimension 85 x 27 for file CSJ.bmp is unusual
Dimension 90 x 20 for file DA62.bmp is unusual
Dimension 85 x 35 for file DenverAir.bmp is unusual
Dimension 85 x 26 for file DHSAS350.bmp is unusual
Dimension 85 x 26 for file DHSC12.bmp is unusual
Dimension 85 x 26 for file DHSTROY.bmp is unusual
Dimension 85 x 25 for file DLX.bmp is unusual
Dimension 79 x 20 for file Draken.bmp is unusual
Dimension 85 x 25 for file DTA.bmp is unusual
Dimension 85 x 22 for file DUB737700.bmp is unusual
Dimension 85 x 28 for file EI-ELZ.bmp is unusual
Dimension 85 x 24 for file EMBRYRID.bmp is unusual
Dimension 85 x 35 for file Estafeta.bmp is unusual
Dimension 85 x 24 for file FAI.bmp is unusual
Dimension 85 x 22 for file flag.bmp is unusual
Dimension 85 x 25 for file FLTOP.bmp is unusual
Dimension 87 x 25 for file FOXFLT.bmp is unusual
Dimension 85 x 25 for file FTAI.bmp is unusual
Dimension 85 x 21 for file GAFA310G.bmp is unusual
Dimension 87 x 26 for file GENATOMICS.bmp is unusual
Dimension 87 x 26 for file GLASAIR.bmp is unusual
Dimension 87 x 22 for file GOODYEAR.bmp is unusual
Dimension 85 x 22 for file HAL.bmp is unusual
Dimension 85 x 25 for file HE.bmp is unusual
Dimension 85 x 26 for file HOUSTONROCKETS.bmp is unusual
Dimension 85 x 32 for file iAero.bmp is unusual
Dimension 85 x 25 for file IAeroAir.bmp is unusual
Dimension 85 x 25 for file IAR (2).bmp is unusual
Dimension 87 x 26 for file IFL.bmp is unusual
Dimension 86 x 25 for file JETLIFE.bmp is unusual
Dimension 85 x 25 for file JETSET.bmp is unusual
Dimension 87 x 20 for file JLN.bmp is unusual
Dimension 87 x 25 for file JNA.bmp is unusual
Dimension 93 x 20 for file JUSDC93.bmp is unusual
Dimension 85 x 30 for file keystone.bmp is unusual
Dimension 85 x 25 for file LIFELINK.bmp is unusual
Dimension 80 x 30 for file LILLY.bmp is unusual
Dimension 85 x 22 for file LKE.bmp is unusual
Dimension 70 x 25 for file LUX.bmp is unusual
Dimension 87 x 26 for file MAHELO.bmp is unusual
Dimension 87 x 27 for file Med-Trans.bmp is unusual
Dimension 85 x 30 for file MEDAIR.bmp is unusual
Dimension 85 x 26 for file MexFedPoL.bmp is unusual
Dimension 55 x 20 for file MexNavyC295.bmp is unusual
Dimension 76 x 20 for file MWGAT75.bmp is unusual
Dimension 76 x 20 for file MWGAT76.bmp is unusual
Dimension 61 x 20 for file N164RJ.bmp is unusual
Dimension 85 x 22 for file N466TM.bmp is unusual
Dimension 45 x 30 for file N700AZ.bmp is unusual
Dimension 85 x 33 for file natca.bmp is unusual
Dimension 92 x 20 for file NOJCRJ2.bmp is unusual
Dimension 86 x 26 for file NORTHAIR.bmp is unusual
Dimension 79 x 20 for file PA18_1.bmp is unusual
Dimension 80 x 32 for file PCSOAC.bmp is unusual
Dimension 87 x 26 for file peakav.bmp is unusual
Dimension 80 x 26 for file Philippine Airlines.bmp is unusual
Dimension 85 x 30 for file PHOENIX.bmp is unusual
Dimension 85 x 21 for file Pilatus.bmp is unusual
Dimension 85 x 35 for file PKW.bmp is unusual
Dimension 20 x 16 for file Poland.bmp is unusual
Dimension 87 x 25 for file PURSUIT.bmp is unusual
Dimension 36 x 26 for file PURSUIT1.bmp is unusual
Dimension 85 x 25 for file radarSCOPE.bmp is unusual
Dimension 85 x 25 for file RADAR_2.bmp is unusual
Dimension 85 x 25 for file RAX_1.bmp is unusual
Dimension 86 x 25 for file RAYTHEON_1.bmp is unusual
Dimension 82 x 20 for file REACHAIR.bmp is unusual
Dimension 85 x 35 for file REDWINGS.bmp is unusual
Dimension 86 x 25 for file rfs.bmp is unusual
Dimension 84 x 20 for file RSP.bmp is unusual
Dimension 86 x 20 for file RTD.bmp is unusual
Dimension 85 x 35 for file Sawyer.bmp is unusual
Dimension 80 x 20 for file Sawyer2 (2).bmp is unusual
Dimension 72 x 30 for file Sawyer2.bmp is unusual
Dimension 85 x 28 for file Sawyer3.bmp is unusual
Dimension 85 x 28 for file SCX_1.bmp is unusual
Dimension 85 x 21 for file SIA.bmp is unusual
Dimension 85 x 25 for file STARLINKLOGO.bmp is unusual
Dimension 86 x 20 for file SU-BAE.bmp is unusual
Dimension 87 x 25 for file Subair.bmp is unusual
Dimension 87 x 25 for file Subair_1.bmp is unusual
Dimension 90 x 20 for file SwissAFF18.bmp is unusual
Dimension 85 x 22 for file sxi.bmp is unusual
Dimension 85 x 22 for file TBM850.bmp is unusual
Dimension 63 x 30 for file TUMA.bmp is unusual
Dimension 89 x 20 for file unc.bmp is unusual
Dimension 20 x 16 for file UnitedStates.bmp is unusual
Dimension 85 x 28 for file USAFSOC D328.bmp is unusual
Dimension 77 x 20 for file USAFTrout99.bmp is unusual
Dimension 85 x 19 for file USDA FS.bmp is unusual
Dimension 90 x 20 for file USDeptofStateDH8C.bmp is unusual
Dimension 87 x 26 for file USDHSB300.bmp is unusual
Dimension 86 x 25 for file USDHSC350.bmp is unusual
Dimension 87 x 26 for file USDHSKINGAIR.bmp is unusual
Dimension 87 x 26 for file USDHSP-3AEW.bmp is unusual
Dimension 85 x 26 for file USDHSPC-12.bmp is unusual
Dimension 87 x 26 for file USDHSPC12.bmp is unusual
Dimension 87 x 26 for file USDHSUAS.bmp is unusual
Dimension 85 x 26 for file USDOA.bmp is unusual
Dimension 90 x 20 for file USDOJAT45.bmp is unusual
Dimension 90 x 20 for file USDOJDH8C_1.bmp is unusual
Dimension 85 x 19 for file usfs.bmp is unusual
Dimension 85 x 22 for file USNVR55.bmp is unusual
Dimension 85 x 22 for file USNVR62.bmp is unusual
Dimension 87 x 25 for file VANBORTEL.bmp is unusual
Dimension 85 x 18 for file VC10.bmp is unusual
Dimension 85 x 22 for file VR62.bmp is unusual
Dimension 85 x 25 for file WILDCL215.bmp is unusual
Dimension 87 x 25 for file WorldStar.bmp is unusual
Test complete, 6583 files checked, 23 errors and 135 warnings
skywarrior
OK, after a couple of hours either deleting files or editing files so that everything is 85X20 rebooting the computer and re-loading files no change.  I notice that when Bas Station loads it hardly sits at loading the Icons when starting. In the past when it worked it would take a couple of minutes to load all files.
I know Kinetic also has files in a different location other than program files X86, but I have bee unable to locate it. I fear the file there is corrupted.  Any ideas?
Quote from: skywarrior on June 24, 2021, 12:18:38 AM
Any ideas?
I can do a remote connect and take a look with you at an agreed time if that will help?
skywarrior
I think that might work, I assume that you are in England?
Let me know the time difference as I am in Tucson AZ.
Quote from: skywarrior on June 24, 2021, 02:59:42 PM
Heavens no.  I'm in Wales  8)
We're 8 hours ahead of you.
So mornings, your time are good, if you're available.  I can do weekends.
skywarrior
Oh, Wales it is.  I can do tomorrow morning after about 9:00 AM local time if that works for you or maybe sometime Sunday Morning.
Tomorrow 9:00 am your time is good.
I've sent you a PM with instructions to setup RemotePC.
Reply nearer the time with the generated ID.
skywarrior
