November 26, 2026, 10:22:28 PM
Base Station no longer showing icons
Started by skywarrior, June 16, 2021, 04:30:53 PM
skywarrior
Hi All,
I have been running a SBS-3 for years along with Base station.  It has work great until about a week ago when it just stopped showing all of the aircraft icons.  I changed nothing and have not installed any new software.
I have looked all through the program and can not find the issue, anyone have any ideas???
Bruce
Quote from: skywarrior on June 16, 2021, 04:30:53 PM
Can you be a bit more specific as to what you're not seeing and where?
Aircraft "icons" on the map or logos in the Aircraft List?
Maybe a screenshot will help.
skywarrior
Hello,
It is not showing the icon on the aircraft list.  No changes were made just one morning it showed no icons.
Which column do you mean, see attached?
State, Status, Flag or Operator?
These are the only columns which can show an icon in the Aircraft List.
skywarrior
Hello,
It is the operator column, the icons have ceased being shown :o
Quote from: skywarrior on June 22, 2021, 12:37:48 AM
Double click on any aircraft to open the pop-up window Aircraft Details.  Then select the Edit Details tab to open the next pop-up window Add/Edit Aircraft Notes.
Is the field Operator Flag Code populated?
If it is, check that you have a matching bmp file in the OperatorFlags sub-folder in the same location from where you launch BaseStation.
If you do, I would recommend you use BMPCheck to check the files in your OperatorFlags folder.
Please report back so we can investigate further if this doesn't fix the issue.
s92driver
In addition to Anmer's suggestion below, please report how many "flags" are in the OperatorFlags directory.
Steve
Quote from: s92driver on June 22, 2021, 07:40:58 AM
Good suggestion, thanks Steve.
skywarrior
Hi Anmer and Steve,
To answer Steve, I do not know the exact number but I have 33+ MB size file for the Icons.
I have downloaded the BMP check, but I am having a devil of a time getting it to load, I even downloaded Java as was instructed but can not get the jar file to open????
Quote from: skywarrior on June 22, 2021, 04:12:49 PM
What are you experiencing when you click on the downloaded BMPChk.jar file?
If you navigate to the OperatorFlags folder using Windows Explorer, it should show the number of files in the bottom status bar.  But it doesn't look like you have too many.
skywarrior
I extracted it and it brings up 2 files, the PDF and the Jar app.  I guess what I need is what program to actually open the file?
Thanks for all your help!!
Quote from: skywarrior on June 22, 2021, 04:41:24 PM
Just double click on the BMPChk.jar file, as explained on Pages 2 onwards of the PDF User Manual!
skywarrior
The file keeps opening up in Notepad which of course is not correct, it just does not launch with a double click
Right mouse click on the file in Windows Explorer and Open With = Java (TM) Platform SE Binary.
Assumes you have Java installed?
skywarrior
I do have it installed.  When I open with Java I see a flash of a black DOS like screen that only lasts seconds but the checker does not open.  Must be other issues here :-\
