November 07, 2026, 07:19:35 AM
ModesMixer2 Remote Receiver
Started by jonboy1081, June 26, 2021, 09:10:57 AM
jonboy1081
Hi All,
I want to set up a second PiAware receiver in a remote location and feed it to my VRS at home, I cannot do any port forwarding etc at the locaton of the remote receiver, my question is can I use ModesMixer2 to do this?, can I set it up so it sends the data to my home DDNS and set up my VRS at home as a push receiver for the remote Pi?.
Any idiots guides available to do this?
Many thanks
Jon
Hi Jon
I just saw this post after replying in your other one. If you can't port forward then you may come a touch unglued. If you follow the guide in the link that I posted in your other thread then you should be able to set-up a remote feeder and have ZeroTier installed as well. If you then also install ZeroTier on your home computer then both machines think they are on the same LAN regardless of where they are. No fiddling with ports required.
R :)
shinesamuel
Need Help to run Modesmixer2 I am getting error in Rpi 3 here is the error
terminate called after throwing an instance of 'boost::exception_detail::clone_impl<boost::exception_detail::error_info_injector<boost::system::system_error> >'
  what():  bind: Address already in use
/home/pi/modesmixer/modesmixer2 --inConnect 127.0.0.1:30005 --inConnect 127.0.0.1:30002 --outConnect beast:feed.adsbexchange.com:51118 --outConnect beast:data.avdelphi.com:24999 --outServer avr:30030 --outServer beast:40001 --outServer beast:31001 --globes 31008:table2:YSSY --outServer beast:31002 --outServer avr:30060 --outServer sbs30006:30006 --location XXXXXXXXXXX --metric --web 8003 --outServer beast:30007 --outServer sbs10001:10001 --outServer msg:30014 --outServer avrmlat:40075 --keep --localtime --silhouettes /home/pi/modesmixer/Data/SilhouettesLogos --db /home/pi/modesmixer/Data/BaseStation.sqb --frdb /home/pi/modesmixer/Data/flightroute/flightroute_w.sqb --filter-expire 20 --filter-nocountry on --flight-expire-time 3000 --log-noconsole --valid-adsb 1:2 --valid-modes 10:4
vordme
- -web 8003   and - outServer avr: 30030  syntax error
--web 8003  and --outServer avr: 30030
