November 25, 2026, 09:28:40 PM
sb3 USB
Started by goflyadam, August 22, 2012, 11:36:42 AM
goflyadam
I just plug in the usb led and the usb is not picking up for some resson and its not lit up on the box where the usb ok
can anyone help
thank you
goflyadam
also the only light on the box is power and auxillary
Have you installed Basestation and run Setup?
Chris-G0WTZ
I suspect you have not updated the firm ware correctly
If that is the case reload the fimware and all should be ok
MIXISM
If you update firmware. Make sure the External antennas are disconnected
Later
