September 20, 2026, 06:24:39 PM
AD LITE problem
Started by Magic440, September 27, 2012, 12:13:20 PM
Magic440
I have been having problems just lately,running AD LITE.
Have uninstalled/re-installed,but still getting the same problem.
It doesn't populate Basestation,until i close the error message!
Running 1.2.3.168,with firmware 306.
As a few of you know,i'm clueless with computers.
This is the message i keep getting.
Occurred : 11:52:34.868 2012/09/27
Error : EDatabaseError - unable to open database file
Last Command : SELECT ModeS, Registration, AircraftID, CurrentRegDate, PreviousID, FirstRegDate, Status, DeRegDate, Manufacturer, Type, SerialNo, PopularName, GenericName, AircraftClass, Engines, OwnershipStatus, RegisteredOwners, MTOW, TotalHours, YearBuilt, CofACategory, CofAExpiry, ICAOTypeCode, Interested, UserTag, InfoURL, PictureURL1, PictureURL2, PictureURL3, UserBool1, UserBool2, UserBool3, UserBool4, UserBool5, UserString1, UserString2, UserString3, UserString4, UserString5, UserInt1, UserInt2, UserInt3, UserInt4, UserInt5, UserNotes, OperatorFlagCode FROM Aircraft WHERE ModeS = '400935'
Last Aircraft : 400935
System Status : 16973824 | 0 | 16973824 | 14105516 | 1527436 | 3.5.4 | 107318808576
Previous : O-WriteToDebugMemo | I-WriteToDebugMemo | I-ReadDBValues | O-ReadDBValues | I-ReadDBValues | O-ReadDBValues | I-ReadDBValues | O-ReadDBValues | I-ReadDBValues | O-ReadDBValues | I-ReadDBValues | O-ReadDBValues | I-ReadDBValues | O-ReadDBValues | I-ReadDBValues | O-ReadDBValues | I-ReadDBValues | O-ReadDBValues | I-ReadDBValues | O-ReadDBValues | I-ReadDBValues | O-ReadDBValues | I-ReadDBValues | O-ReadDBValues | I-ReadDBValues | O-ReadDBValues | I-ReadDBValues | O-ReadDBValues | I-ReadDBValues | O-ReadDBValues
Any help,greatly appreciated.
I assume that's a Basestation error message?
Do you get it if AD Lite isn't running?  Have you tried closing Basestation, restarting it and then AD Lite?
Magic440
Yes,Mike.The Basestation pops a warning up.
I just had a Tornado trigger the message.
That was already in my database!
I used to get the same message,whilst running SBS Populate.
Also getting a look-up error on PP.
It may be that your database has some corrupt data.  You could run some tets to check the integrity of the Basestation.sqb file.
Magic440
Thanks Mike.
How would i run the test? Is it a simple procedure?
Would i have to download anything?
Sorry for all the questions.
Just rushing off to the Hamfest.  Will reply more fully tomorrow.
Magic440
Would it help,if i sent you a copy of the sqb.file?
Magic440
You can try sending it as attachment to:
Info@radarspotting.com
Otherwise you'll need to use Yousend IT or DropBox.
Magic440
File sent Mike.Off to work now. :(
File received.  I'll take a look later this evening.
Magic440
Managed to get ADLite working,the path to the default location was c:Program Files,but should of been C:Program Files.Ihave now installed the full version on a trial period,all is running smoothly,but struggling to get any photos to show.I tried editing the xsl file,but not sure if i have done it right.
This is what i have at the moment.
<?xml version="1.0" encoding="iso8859-1"?>
<xsl:stylesheet version="1.0" xmlns:xsl="http://www.w3.org/1999/XSL/Transform">
<xsl:template match="/">
<html>
  <head>
    <link rel="stylesheet" href="basestation.css" type="text/css"/>
  </head>
  <body>
<xsl:variable name="AirlineICAO" select="substring(//currentflight/callsign,1,3)"/>
<meta http-equiv="refresh" content="5"/>
    <table>
      <tr>
        <td>
          <div class="entrybox">
            <table width="410">
            <tr>
                  <td width="200" height="150">
              <img src="C:\Program Files\Kinetic\BaseStation\JPGPhotos\{//regdata/registration}.jpg" width="200" height="133" border="0" />
            </td>
                 <td width="200" >
              <img src="C:\Program Files\Kinetic\BaseStation\JPGPhotos{//regdata/registration}_A.jpg" width="200" height="133" border="0" />
            </td>
               </tr>
           </table>
         </div>
        </td>
      </tr>
    </table>
    <table>
      <tr>
        <td>
            <table width="410">
              <tr>
                <td width="200">
                  <span class="entrycaption">ModeS Code :    </span>
                  <span class="entrydata"><font color="Blue"><xsl:apply-templates select="//transmission/modes"/></font></span>
                </td>
                <td width="200">
                  <span class="entrycaption">Callsign :   </span>
                  <span class="entrydata"><font color="Blue"><xsl:apply-templates select="//currentflight/callsign"/></font></span>
                </td>
              </tr>
              <tr>
                <td width="300">
                  <span class="entrycaption">Registration :     </span>
                  <span class="entrydata"><font color="Blue"><xsl:apply-templates select="//regdata/registration"/></font></span>
                </td>
                <td width="200">
                  <span class="entrycaption">Type :        </span>
                  <span class="entrydata"><font color="Blue"><xsl:apply-templates select="//regdata/type"/></font></span>
                </td>
              </tr>
              <tr>
                <td width="200">
                  <span class="entrycaption">Serial No :           </span>
                  <span class="entrydata"><font color="Blue"><xsl:apply-templates select="//regdata/serialno"/></font></span>
                </td>
                <td width="200">
                  <span class="entrycaption">ICAO :        </span>
                  <span class="entrydata"><font color="Blue"><xsl:apply-templates select="//regdata/ICAOTypeCode"/></font></span>
                </td>
              </tr>
              <tr>
      <td width="200">
                  <span class="entrycaption">Country :             </span>
                  <span class="entrydata"><font color="Blue"><xsl:apply-templates select="//transmission/country"/></font></span>
                </td>
                <td width="200">
                  <span class="entrycaption">Operator : </span>
                  <span class="entrydata"><font color="Blue"><xsl:apply-templates select="//regdata/registeredowners"/></font></span>
                </td>
              </tr>
              <tr>
                <td width="200" height="20"></td><td>
                  <img src="C:\Program Files\Kinetic\basestation\OperatorFlags\{$AirlineICAO}.bmp" width="90" height="20" border="0" />
           </td>
              </tr>
            </table>
            <table>
            <tr>
              <td width="400">
               <span class="entrycaption">Route :                </span>
               <span class="entrydata"><font color="Blue"><xsl:apply-templates select="//currentflight/Route"/></font></span>
              </td>
            </tr>
            </table>
          </div>
        </td>
      </tr>
    </table>
    <table>
      <tr>
        <td>
           <table width="410">
             <tr>
              <td width="200">
                <a href="http://dm.airliners.net/search/photo.search?sort_order=photo_id%20DESC&amp;first_this_page=0&amp;page_limit=30&amp;&amp;regsearch={//regdata/registration}&amp;thumbnails=noinfo" target="new">
          <span class="entrycaption">Airliners.net search : <xsl:apply-templates select="//regdata/registration"/></span></a>
           </td>
               <td width="200">
                <a href="http://www.planepictures.net/netsearch4.cgi?stype=reg&amp;srng=2&amp;srch={//regdata/registration}&amp;offset=0&amp;range=10" target="new">
                <span class="entrycaption">Planepictures.net search : <xsl:apply-templates select="//regdata/registration"/></span></a>
              </td>
            </tr>
            <tr>
              <td width="200">
                <a href="http://www.jetphotos.net/showphotos.php?offset=0&amp;where=search|-2|-2|-2|-2|{//regdata/registration}|15|1|||||||-2|-2|-2|-2|||15|1||-2|-2||||reg|1||||||-2|||1|||||||&amp;newdisplay=8" target="new">
                <span class="entrycaption">Jetphotos.net search: <xsl:apply-templates select="//regdata/registration"/></span></a>
              </td>
              <td width="200">
                <a href="http://www.airframes.org/reg/{translate(//regdata/registration,'ABCDEFGHIJKLMNOPQRSTUVWXYZ','abcdefghijklmnopqrstuvwxyz')}" target="new">
                <span class="entrycaption">Airframes.org Search : <xsl:apply-templates select="//regdata/registration"/></span></a>
          </td>
            </tr>
          </table>
          </div>
        </td>
      </tr>
    </table>
    <table>
      <tr>
        <td>
            <table width="410">
              <tr>
                <td>
                  <span class="entrycaption"><font color="Maroon">Note : </font></span>
                  <span class="entrydata"><font color="maroon"><B><xsl:apply-templates select="//user/notes"/></B></font></span>
                </td>
              </tr>
            </table>
          </div>
        </td>
      </tr>
    </table>
  </body>
</html>
</xsl:template>
</xsl:stylesheet>
Do you have image files in the folder that the XSL is looking for and named using the correct naming convention?
Magic440
Not sure what i'm looking for Mike.
The photo's are named G-MAPS_A   etc
