May 17, 2026, 05:09:05 PM
operator flags
Started by mcfcmike64, February 02, 2022, 12:53:45 PM
mcfcmike64
 when i install operator flags my my sbs stops working
Hi Mike
Have you tried checking all your operator flags with the BMPChk software to see if they are all the correct size etc
https://radarspotting.com/forum/index.php?action=tportal;sa=download;dl=item54
mcfcmike64
yes they are from radarspotters web site
I presume that when you remove the operator flags the SBS starts working again?
Hopefully Anmer will be able to shine some of his knowledge on this problem when he comes on next.
Quote from: mcfcmike64 on February 02, 2022, 12:53:45 PM
Can you be more specific?  Do you get an error message?
And as suggested by rikgale, have you checked your OperatorsFlags folder using BMPCHK?
mcfcmike64
logos  i am using are paul m's.  error message exception eoutof access violation in module NTDII.DII
Quote from: mcfcmike64 on February 02, 2022, 02:57:37 PM
Have you recently installed these bmp files and only since had the error message?
Can you please respond to the earlier question:
QuoteAnd as suggested by rikgale, have you checked your OperatorsFlags folder using BMPCHK?
mcfcmike64
it started to do this a couple of weeks ago as soon as i install logo's sbs stop working uninstall them it works without operator flags
How many logos are you trying to install? There is a limit on the No. that BS can load.
mcfcmike64
paulm's logos are in two parts
And the unanswered question?
mcfcmike64
below his downloads it say's checked by BMPCHK do i still need to do this
Quote from: mcfcmike64 on February 02, 2022, 06:00:28 PM
I would just in case there's a problem file.
If you're still having issues, I can do a remote connect and take a look with you.  But not today.
mcfcmike64
ok thanks wiil let you know how i get on
