May 13, 2026, 03:26:08 PM
PlanePlotter 6.5.8.9 Released
Started by Triple7, May 23, 2022, 02:46:20 PM
From Bev,
If you are interested in the Beamfinder feature in PlanePlotter, this version :
"www.coaa.co.uk/planeplotter6_5_8_9.exe"
has a revised "one-click" generator for the required "radar.txt" file.  It now also includes a search for the IID (II/SI) labels on radar pings, in addition to the Mode-A and Mode-S ping repetition time characteristics to enable it to identify a radar site.
It also has an additional test feature for putative radar sites.  In Tools...Edit, if you double click on a radar site symbol, you should see a rotating vector around the selected site with little circles that pop up when an aircraft pings in the characteristic way for that site.  It is a quick way to diagnose ambiguous site characteristics.
There is a revised tutorial video here :
"www.coaa.co.uk/creating-radar-txt.mp4"
which may be easier to understand than reading the revised help file.
Note that it seems that the Mode-A and Mode-S methods are not very useful for sites in the UK because the ping rates for each site are not single valued, but the IID (II/SI) method gives some useful results.
By contrast, I believe I am right in saying that the IID (II/SI) methods do not work in Germany, where the II/SI codes are not unique to a single radar site, but the Mode-A/S methods might work there.
All three work well here!  Good Luck!
Bev
COAA
