August 27, 2026, 01:09:41 AM
Flightstick software
Started by ryan hothersall, September 02, 2022, 10:50:59 AM
ryan hothersall
Looks like my Kinetic SBS-1 has come to the end of it's life.
Been looking at the Airnav Flightstick to replace it.
Will this software work with it?.
https://www.radarbox.com/legacy-software
Quote from: ryan hothersall on September 02, 2022, 10:50:59 AM
It claims it does.  You will also need a Raspberry Pi with suitable software.
There are alternative DVB-T "sticks" you could consider though my RadarBox Flightstick works OK.
I have PiAware installed on my RPi and use it (with MLAT plots) to feed data to Basestation via ModeSMixer.  Works a treat and I get a free FlightAware Premium account..
By the way, how have you determined your SBS is defunct?
ryan hothersall
I dug out an old windows 7 laptop, and set it up outside and since I live near a GA airport where flight schools operate from. The larger school's aircraft are fitted with ADS-B and when there were aircraft flying overhead, was getting nothing.
Any lights on the SBS?
Did you re/install Basestation on the old laptop ot had it been installed before?
ryan hothersall
Power light and light indicating USB were on and 1,2 sometimes 3 blue lights flashed on and off.
Yes software was newly installed.
Sounds like the SBS is working OK.
Do you have the USB drivers installed?
ryan hothersall
Yes I thought I did have the drivers installed.
Have you tried connecting via Ethernet as you mentioned in your post on another thread?
ryan hothersall
I have given up on the SBS-1 and I am trying the Airnav Flightstick.
I also have dug out an old windows laptop and trying that.
Quote from: ryan hothersall on September 06, 2022, 09:28:42 AM
The FlightStick normally connects to a Raspberry Pi running appropriate software.
