November 25, 2026, 10:12:22 AM
SBS-1 sqb file path
Started by REACHhunter, October 19, 2022, 08:21:59 PM
REACHhunter
Evening all, I have just moved my SBS-1 and all associated files over to a new pc, but when I try to create a path to the SQB with SQlite, the SQB file doesn't show. Its clearly there in the folder however, and is running on my Basestation ok. Should I have downloaded the BS184 software fresh and just dropped my old sqb into it maybe? Also, I have recently developed a fault when I try to edit from the Basestation screen via a double click on an airframe, I get an annoying msg that tells me to email kinetic with details, and so I cannot edit any aircraft from the screen.
Ray
It depends from where you've copied and pasted the files.
What was/is the folder path for Basestation on the old and new PC?
If it's a new install of SQLite, you will need to associate the .sqb extension with SQLite otherwise it will not show as being a file type it can open.
In SQLite -  Tools>>Options>>File Associations click 'new' add .sqb OK that and you should then see basestation.sqb as a file that SQlite can open.
