August 27, 2026, 12:36:15 AM
F01339 UNID
Started by Sketco, March 20, 2023, 08:08:43 PM
Sketco
F01339 UNID AIRCRAFT CALLSIGN "V" LOCATED ABERSOCH POPPED UP 8 TIMES TODAY 20/03/23
ALSO, ANYONE HAVE THE REG FOR 43FF5E WILDCAT HMA2 C/S VARIOUSLY "VENGANCE 25", "CARTEL"
Sketco
F01339 SCREENSHOT. COMES AND GOES (DRONE?)
jonboy1081
Hi Sketco,
What feed are you pulling that from?
Sketco
jonboy1081
Hi Sketco,
Sorry about that, it seems that someone maybe sharing my AIS feed in to ADSBHub, this is actually RNLI Lifeboat 13-39, the ICAO is in an unallocated block which I use for Lifeboats, that feed has been pulled now so hopefully you wont see that again. :)
Sketco
 AH GREAT,
Thanks for the info.
Quite a bit of new drone activity up that way, so I wondered.
Interesting that AIS turns up in the feed.
I'm now left wondering if aishub feed could be used in this manner with virtual radar server. A bit like COAA's combiplotter.
Anyway cheers for the reply
jonboy1081
It absolutly can be fed in to VRS, I take the AIS Hub feed in to AIS-Catcher, then in to ais2adsb to filter the lifeboats and convert the MMSI to ICAO and then in to VRS, it takes a bit of work but it works very well, I've setup a SAR only feed on my VRS. :)
Sketco
Well, now I'm excited. Thanks for sharing.
This is something I would like to implement in the coming months.
I'm sure there is plenty of opportunity to fall flat on my face during the implementation.
If I get stuck, would you mind if I tap your knowledge from time to time?
jonboy1081
Yeh sure, feel free to drop me a PM if you need any info. :)
Sketco
THANKS, VERY KIND OF YOU.
