November 22, 2026, 12:08:18 PM
Default Radar View
Started by merseyman123, May 11, 2023, 06:34:22 AM
merseyman123
Hello
Is there anyway you can arrange your basestation software so it has a default map it goes to when you load it up. Mine keeps going over to Belgium which was the last place I worked on adding approaches & airport templates. I'd like my home location tab but I'm unsure of what to do.
Have a look at the menu item Radar>>Add Radar Screen Tab (Ctrl-A). Arrange it to suit - viewing distance, set view Center and Bearing, which plots you want to see etc. Then save the tab... Radar>>Save Radar Screen View give it a name and then if it's the last tab you have used, it should be the default the next time you open BS.
I hope that's what you wanted.
merseyman123
Hi Tim
Yes that's great does just the job
Thanks for your help
Gareth
