November 25, 2026, 10:12:16 AM
error loading sbs1e
Started by frazer macfadyen, September 07, 2023, 02:45:03 PM
frazer macfadyen
hello all . my sbs which i use daily , As of today is showing two error codes
and after a good six hours i am still unable to rectify
frazer macfadyen
sorry sent same one twice
her is the other error
How many bmp files do you have in the OperatorFlags folder?
frazer macfadyen
Good afternoon Anmer sorry for late reply...
Thanks.  I suspect there lies your problem, too many files.
It's easy to check.
Close Basestation.
Rename the OperatorFlags folder to "OperatorFlagsOld"
Make a new folder OperatorFlags in the same directory, Basestation.
Restart Basestation and let it run for a while.  Any error messages?
frazer macfadyen
Thanks Anmer will give it a try ,Before i do  what happens to the original files does that become obsolete?
will the new file mean i start from scratch.and i will have repopulate it
frazer macfadyen
Many thanks Anmer you were indeed correct , I renamed the file as you explained
so now i just need see how i can repopulate my previous operator flags
20,000 bmp files is a lot and I've seen these error messages appear at around 10,000.
Try culling a few and maybe run BMPCHK in case there are some rogue ones in the folder.
frazer macfadyen
Thanks Anmer .. but the BMPCHK which i loaded last night cannot locate my files
even though i placed it directly into the basestation file
Please read the manual about setting the Dir path.
