October 19, 2026, 06:52:43 AM
Globe-s rtl
Started by Steveyboy1234, January 02, 2024, 08:51:15 AM
Steveyboy1234
Hi there,
Anyone using Globe-s rtl on windows 10?
Runs ok but don't seem to be able to get the text to display for the following
1 time
2 altitude filter upper and lower
3 meter data
4 flight strip
5 bearing distance data on selected aircraft
Any help appreciated
Cheers Steve
Welcome
What receiver are you using?
Steveyboy1234
Im using SDR RTL blog v3 dongle and rtl1090 to decode
Cheers Steve
Thanks.  Were you seeing the missing data before on a different setup?
Steveyboy1234
Nope. This is the first time I'm using this.
I've not seen the data. Tried re installing but no joy
The aircraft data labels are fine and everything else appears to work fine
Does RTL1090 decode these messages?
Steveyboy1234
Yep RTL1090 all functioning well and decoding. Globe-s rtl connects to it fine. Aircraft seen on the radar screen with correct data labels.
Just no text in the UTC and LT box at the top of the screen. No text in flight strip box that appears on the top when you mouse over an aircraft. + the other stuff mentioned in OP.
Cheers Steve
To the best of my knowledge Gloce-S is no longer supported.  Maybe there are members here who still use it who can help?  I'm afraid I've run out of suggestions.
Steveyboy1234
Thanks for the help anyway.
I know there are probably more Moden alternatives but I like the retro feel of it.
Surprisingly similar to current ATC screens at place I fly
I'll let the post know if I make any progress
Cheers Steve
