June 01, 2026, 04:15:10 AM
ACARSD 1.7 plugin
Started by markwolfe0404, September 04, 2024, 03:52:02 PM
markwolfe0404
Hi all
A while ago you helped me find a copy of the above program.  The problem is it no longer shows a picture of the aircraft.  Reading logs on Google the fix is to find a plugin called "Use a different picture database iconserver V1.12b" written by KJM at acarsd@acarsd.org.  The ask is does anyone have access to a copy I can download.
Many thanks in advance
Kind regards
Mark
Digging through old stuff I found the attached file.
I think it needs to go into the acarsd\plugins folder, wherever you have installed acarsd to.
Might be of use, might not, worth a try!
I did this to install the plugin...
Just a little disclaimer, I don't use acarsd, just played around with old files...
markwolfe0404
Hi Keef
Many thanks I have installed the plugin but still trying to get this to work but appreciate your help and support here.
Kind regards
Mark
