November 22, 2026, 11:11:25 AM
Problem with adding Airport Outlines in Basestation
Started by Davfog, September 17, 2024, 04:08:58 PM
Davfog
I'm visiting a few Asian countries in a month's time and have downloaded the following outline files which don't appear on my chart display after I've copied them to my outlines folder.
Taiwan Taoyuan International RCTP.out
Taipei Taoyuan.out
Taipei Songshan RCSS.out
Taipei Songshan.out
Shanghai Hongqiao ZSSS.out
Pudong.out
Shanghai Pudong ZSPD.out
Seoul Incheon.out
Seoul Incheon RKSI.out
Seoul Gimpo.out
Seoul Gimpo RKSS.out
Tokyo Narita.out
Tokyo_Narita_RJAA.out
Only 2 of the total files I downloaded worked, they were Beijing Capital and Tokyo Haneda.  I'm still looking for an outlines file for Beijing Daxing if anyone has one please.
I'm running my SBS-1e on a Lenovo laptop running Windows 10 64 bit operating system
Edition   Windows 10 Home
Version   22H2
Installed on   ‎15/‎03/‎2021
OS build   19045.4894
Experience   Windows Feature Experience Pack 1000.19060.1000.0
Basestation software version 1.2.4.184, firmware version SBS-1e build 402
Basestation software runs from Program Files (x86) and works fine.  I also use an add-on, Basestation Analyser from Aerodata but it is no longer available as there will be a new version coming out in the near future (I hope!)  When the new BSA version is available, I plan to buy a new laptop and reinstall from scratch, running Basestation off a folder off the root drive.
In Display Settings ---> Data Files, all the airport outlines I have installed start with AFB, AFM or AFP followed by an underscore and the airport name.
I also run Planeplotter on the laptop but won't reinstall it on the new laptop as I feel it is sadly lacking.
So, the question is, how do I get these outline files to show?
regards,
Dave
s92driver
Apologies for such a basic point, but you don't mention if you have "ticked" the appropriate file names in the Display Settings ..... Data Files window.
Davfog
All ticked that are visible.  None of the ones listed above though.
I'm away until Friday. I can take a look at this issue when I return.
acarslogger
When you add new outlines into your outline folder, Basestation doesn't know about them. Try Settings > Reload > Outlines and it should list the new ones.
Stuart
Davfog
I wasn't aware of that feature and when I tried it, I got this error message.
App: BaseStation
Version: 1.2.4.184
Occurred : 12:25:27.777 2024/09/18
Error : EAccessViolation - Access violation at address 004F83B7 in module 'BaseStation.exe'. Read of address 00000000
Last Command : UPDATE Flights SET Callsign = 'PJJ1A' WHERE FlightID = 5409613
Last Aircraft : 45214A
System Status : 16580608 | 0 | 16580608 | 12848740 | 3018152 | 3.7.11 | 871963832320
Previous : O-WriteToDebugMemo | I-WriteToDebugMemo | O-WriteToDebugMemo | I-WriteToDebugMemo | O-WriteToDebugMemo | I-WriteToDebugMemo | O-WriteToDebugMemo | I-WriteToDebugMemo | O-WriteToDebugMemo | I-WriteToDebugMemo | O-WriteToDebugMemo | I-WriteToDebugMemo | O-WriteToDebugMemo | I-WriteToDebugMemo | O-WriteToDebugMemo | I-WriteToDebugMemo | O-WriteToDebugMemo | I-WriteToDebugMemo | O-WriteToDebugMemo | I-WriteToDebugMemo | O-WriteToDebugMemo | I-WriteToDebugMemo | O-WriteToDebugMemo | I-WriteToDebugMemo | O-WriteToDebugMemo | I-WriteToDebugMemo | O-WriteToDebugMemo | I-WriteToDebugMemo | O-WriteToDebugMemo | I-WriteToDebugMemo
acarslogger
The chances are that you have a 'bad' outline file.
Look in the Basestation 'Debug' window. It may show the outline file that it didn't like.
Stuart
I agree with Acarslogger. Most likely a bad out file. I'll help fix this when I'm back on Friday.
Davfog
Where exactly do I find the debug information?  I've searched my C: drive for a debug file but can't find one.
Dave
acarslogger
Hi Dave,
Basestation > Settings > Toolbars > Debug.
It should display a new toolbar icon. Hover over it, and it should show 'Toggle debug'.
Stuart
Davfog
Thank you, most useful, I wasn't aware of this feature.  These are the last few lines.
2024/09/18 : 14:31:09.592 : Outline file loaded
2024/09/18 : 14:31:09.592 : Loading outline file C:\Program Files (x86)\Kinetic\BaseStation\Outlines\AFP_Heathrow EGLL.out
2024/09/18 : 14:31:09.608 : Outline file loaded
2024/09/18 : 14:31:09.610 : Loading outline file C:\Program Files (x86)\Kinetic\BaseStation\Outlines\AFP_Hong Kong Island.out
2024/09/18 : 14:31:09.610 : Outline file loaded
2024/09/18 : 14:31:09.610 : Loading outline file C:\Program Files (x86)\Kinetic\BaseStation\Outlines\AFP_Hong Kong Lantau Island.out
2024/09/18 : 14:31:09.620 : Showing EAccessViolation:Access violation at address 004F83B7 in module 'BaseStation.exe'. Read of address 00000000
Davfog
Thank you gents for your help, I have removed the Hong Kong Lantau Island Outline and it now works fine.
Dave
Davfog
Mind you, I still need an outline file for Beijing - Daxing.  Maybe Anmer can help once he's back home and up and running?
Thanks again.
I'll take a look at this tomorrow when I'm back home.
