November 25, 2026, 12:53:37 AM
changing to SBS3
Started by acw6535, October 26, 2024, 12:05:20 PM
acw6535
I need some advice.I`ve been using an SBS-1 since 2005.I`ve installed it on several computers,over the years.Currently running great on one of those micro computers.It`s never let me down,but...
I`ve acquired an SBS-3,as I heard it was a bit more sensitive.
Do I just swap the exe files over,or is there something else I have to do?
Allen
If you're just swapping the receiver (SBS-1 to be replaced by an SBS-3) you shouldn't need to change anything on the computer.  Unless you plan to connect via Ethernet rather than USB.
acw6535
Quote from: Anmer on October 26, 2024, 01:39:49 PMIf you're just swapping the receiver (SBS-1 to be replaced by an SBS-3) you shouldn't need to change anything on the computer.  Unless you plan to connect via Ethernet rather than USB.
Great,thanks Anmer
I would recommend updating BaseStation to the latest version 184.
Files can be found in our Software section.
