November 25, 2026, 12:53:46 AM
Connecting my SBS-3 to a new router
Started by Falcon200EX, December 21, 2024, 04:31:54 PM
Falcon200EX
Hi, I have an SBS-3 connected via ethernet to my existing router. In a couple of weeks time BT are installimg a new router and was just wondering if i just need to connect my SBS-3 up to the new router and it will work, or would there be further connection details required to get my SBS-3 back up and running?
Many thanks
It depends on the router, possibly allocating a different local IP address to the SBS-3.
The SBS-3 default local IP address is 192.168.1.170.
If the new router has a default address in a different range, such as 192.168.0.nnn, you will have to set a new SBS-3 local address.
Post back here if you need any help when the router has been changed.
Falcon200EX
If you need help it will be an easy fix.
Falcon200EX
Hi Anmer,
New router has arrived and I've connected the SBS-3 to it and all is working fine.
Thank you for your help.
Best regards
