November 15, 2026, 10:14:33 PM
Virtual Radar Map Error?
Started by Dreamliner787, March 14, 2025, 08:42:23 AM
Dreamliner787
hi,
when I open up Virtual Radar the map does not display properly. Can anyone tell me what causes this , is it a problem with the browser or windows 11 ? I've tried it with a different browser same result.
thanks
Does it display OK if you zoom in?
Dreamliner787
not really , I've tried zooming in and out . it either stays the same or the image is blurred.
I've noticed this on on radar exchange as well . it sems to happen when I'm looking at my own feed.
How much RAM do you have on the computer?
Dreamliner787
32Gb Ram 2x16
Could I ask you a question not related to this on, Why is my Basestation.ini file in the virtual store ?, shouldn't it be in the Kinetic/Basestation folder ? why does it do that ?
thank you
Quote from: Dreamliner787 on March 14, 2025, 09:39:05 AM32Gb Ram 2x16
That sound OK.  Does Google Maps open OK for you?
Quote from: Dreamliner787 on March 14, 2025, 09:39:05 AMCould I ask you a question not related to this on, Why is my Basestation.ini file in the virtual store ?, shouldn't it be in the Kinetic/Basestation folder ? why does it do that ?
Did you install BaseStation to the default location in Program Files or in a directory of choice?
What's the folder path for your BaseStation.exe?
Dreamliner787
yes , I can open google maps in my browser ,no problems.
If I change the settings in VR Tools/Options to google maps I get an old version of google maps displayed correctly with a watermark,
with a msg This page can't load Google Maps correctly.
C:\Program Files (x86)\Kinetic\BaseStation
Quote from: Dreamliner787 on March 14, 2025, 09:58:12 AMyes , I can open google maps in my browser ,no problems.
But the whole map displays when you zoomn in and out, ignoring th watermarks?
How about OpenStreetMap, does that work OK?:
https://www.openstreetmap.org/
Quote from: Dreamliner787 on March 14, 2025, 09:58:12 AMC:\Program Files (x86)\Kinetic\BaseStation
Why do you also have a Kinetic\Basestion folder?
Quote from: Dreamliner787 on March 14, 2025, 09:58:12 AMshouldn't it be in the Kinetic/Basestation folder ?
Dreamliner787
Ref Google maps,
had to nip out there for a bit  ;D
It displays ok, if I zoom in and out theres a little bit of lag displaying map but then displays ok.
Ref https://www.openstreetmap.org/
the map loads the same as above.
not sure what you mean ?
You asked about that folder.  Why?
Your BaseStation appears to be installed in ProgramFiles so you shouldn't have a Kinetic folder.
If you Google Windows VirtualStore it will explain why some files are there.
Dreamliner787
"Your BaseStation appears to be installed in ProgramFiles so you shouldn't have a Kinetic folder".
does it make any difference ?
There's nothing more I can add.
Dreamliner787
I've answered as best I can.
Google VirtualStore to understand how it works.
I assume you don't have a folder named Kinetic/Basestation. In which case why ask the question?
