November 25, 2026, 12:51:13 AM
Old SBS3 config / Ethernet ??
Started by Urania, September 25, 2025, 08:22:02 AM
Urania
Long time, hope everything is well.
I am trying to make it working connected to my ethernet network.
It doesn't want to work ... No light :)
I have tried three different cables from cat5 to cat6.
Move from USB to Etehrnet .... Ethernet to USB and vice versa ....
Fresh install ....
[DataInterface]
LStat=48882458
SocketIntfIPAddress=192.168.206.250
SocketIntfPort=10001
Doesn't show on my network.
Ideas ?
Welcome back  ;)
I assume you're using BaseStation with an SBS-3?
Has it ever worked using Ethernet?
Have you configured BaseStation to connect to the SBS-3 in Settings?  What IP address and port number are set?
Do you know your local IP address range?
Urania
#2
Yes I am running my BS with my SBS3.
Yes it was working over ethernet.
Yes I know my local IP range, I am the admin of my network ;)
I have connected the box to my network in the right VLAN. I am supposing that there is no DHCP client in the box ??
See the first post for the IP number.
And it doesn't create the sqlite3 DB ....
Thx
Worse case scenario the SBS-3's Ethernet has failed.
Have you checked SBS-3 works OK using USB?
I assume you've tried pinging the SBS-3?
I have a utility to reset the Lantronix back to the default IP and port if you want to try it?  You would then need to set the IP address and port to whatever you want to use.
Silly mention.  Is BaseStation Data Source set to "Use Network"?
Urania
#6
:'(  of course ....
But everytime I am moving in both way to USB or Ethernet, I have a popup with a BS error ... And it doesn't work even if using USB ... How to you choose the right COM port ?
I've emailed you a link to Lantronix.  But if SBS-3 doesn't work using USB, does it have a suitable power supply
Urania
Kinetic Avionics Limited.
Lantronix Xport setup utility V1.1
Binding to UDP
Ready.
Sending Version Query UDP Datagram to Broadcast Port: 30718
Confirmed : Sent datagram : size  4
Sending Config Page 0 UDP Datagram to Broadcast Port: 30718
Sending Config Page 3 UDP Datagram to Broadcast Port: 30718
Sending Config Page 7 UDP Datagram to Broadcast Port: 30718
Sending Config Record 7 - Broadcasting KAL Config to all units
Confirmed : Sent datagram : size  130
Sending Config Record 3 - Broadcasting KAL Config to all units
Sending Config Record 0 - Broadcasting KAL Config to all units
Confirmed : Sent datagram : size  124
Sending Reset to Broadcast Port: 30718
Urania
I am trying to do it in a second laptop with fresh install.
I need your auth to dl it.
Thx
Urania
ok done, no need :)  I have exactly the same thing that my main pc (running Lantronix) ...
But when running on my laptop (usb) , I have now an active session. And I know see the scope ... But I am using for this test my old sqlite3 ... How to generate a fresh one ?
Quote from: Urania on September 25, 2025, 10:01:06 AMBut I am using for this test my old sqlite3 ... How to generate a fresh one ?
Do you need a "fresh" sqlite3?
Does the SBS3 now work using Ethernet?
As for SQLite3, Google it and go from there.
