November 21, 2026, 08:09:23 AM
ADSB Trident - Beta Release
Started by evangel, March 31, 2026, 05:28:33 PM
evangel
ADSB Trident
I have been a fan of Sergsero's utilities from 2017 and The last few years he disappeared due to war.
About that time Google stopped the API support, my key would not work anymore.
At the same period I tried various other utilities as Basestation, Globe-s, Skyaware, VRS, 3D and Planeplotter.
So I decided, with AI's help, to combine all different views into one program with different views while maintaining the in/out traffic management for different ports and short of "revive" the old Modesmixer, and not only in theory.
The program requires an ADS-B receiver capable to transmit Beast traffic, preferably a Raspberrypi and, as what I call a "adsb swiss army knife", it can broadcast to different ports and different formats like the Modesmixer2 program did It is accompanied with a 20-page detailed manual. Read The manual !
It is meant to be a Windows 10/11 utility and requires Webgl.
It was developed in Greece and this is why most of screenshots are taken using my RPi here, you will want to set your Home latitude/longitude coordinates, and your RPi parameters, in the first screen that appears when you run the program,
so the map will be centered at your area.
By the way, I changed the name from MM2026 to ADSB Trident.
I welcome everybody to try-it out and any comments or suggestions are welcome, hoping you enthusiasts will find it reach of features, and easy to use.
Here is the link for Google drive downloads. Unzip the file and run Setup.exe to install the program, normally at C:\ADSB Trident, you may change the default path, but not the hard-coded folder name as it will not run properly.
https://drive.google.com/file/d/1QSuy8VkW3ThZkB1Bo2pguey78vypfGuh/view?usp=sharing
Evangelos
Oldfella
Thank you Evangel for your efforts to allow us to enjoy your handiwork. I have the program up and running and just a matter of changing the databases around for my locations. Well done. ;)
Oldfella
evangel
#2
1st Apr 2026
Hi all
Due to corrections I've made please download the latest version from the link below
Thanks / Evangelos
ADSB Trident - update 1
PS. You must delete the max range and create your own and also delete the heywhatsthat data that apply only to my site.
evangel
#3
Here is the new Upd 2
Enjoy
ADSB Trident - update 2
evangel
evangel
abcd567
#7
adsb-trident-linux-v2.0.8
Quote of post in Flightaware Forum (Posted by evangel at end of March 2026)
QuoteHi
this update takes care some database and flights routes issues.
if you want to preserve basestation.sqb and flightroutes.sqb you must copy before
you install the new version. please advise if everything works.
download v.2.0.8 update
