September 23, 2026, 01:50:27 PM
No Squawk codes
Started by Snoopy, May 18, 2026, 07:43:04 AM
Snoopy
Hi all
I am using a Kinetic puck, and it is working fine, except for the fact that no Squawk codes are showing up.
Anyone have any idea why that might be?
On what application are the squawk codes not appearing?  BaseStation, VRS or other app?
And are there none at all, or some are displaying, others not?
Snoopy
Base Station.
No codes at all
Where is BaseStation do you expect to see the squawk code displayed?
If you double click an aircraft to open the pop-up Aircraft Details window, is the Squawk missing, see attached?
Snoopy
I don't see squawks in the aircraft list or in the aircraft details.
Thanks again.
What Timeouts do you have set>
Snoopy
That solved it. Thanks.
I had "Ignore Non ADS-B Mode-S Messages" ticked...  :-\
But that screenshot solved the issue!
Thank you very much for taking the time to answer.
Great.  But if I tick "Ignore Non ADS-B..." I still see squawks. :-\
Out of interest, what are your timeout settings?
Snoopy
Sorry, I only just saw this.
These are my current settings.
You have very long timeouts.
Change "Remove" to 30 and "Delete" to 300.
The check "Ignore Non ADS-B Mode-S Messages" again.
Do you see squawk codes?
Snoopy
Thanks. Yes, Squawk codes are still coming through.
I think the missing codes were due to the long timeouts.
