September 05, 2026, 02:50:34 AM
PlanePlotter 6.7.5.9 Released
Started by Triple7, June 15, 2026, 04:24:52 PM
From Bev:
PlanePlotter version 6.7.5.9 is on the web site now.
http:www.planeplotter.com#download
The web site is still showing 6.7.5.7 so use this: http://www.coaa.co.uk/planeplotter6_7_5_9.exe
---Usual boilerplate---
If you have a version-specific firewall or security system, you may have to reassure it that the new version is permitted to access the Internet. Be aware that increasingly, security systems treat any new file as a threat without any justification except that it is new. Please don't write to me about it; write to your security system provider and ask them to make their program smarter.
The following are the cumulative changes since the last published version 6.7.3.9
Release 6.7.4.1
fix uninitialised VDL2 pointer
Release 6.7.4.2
add (case sensitive) accelerator keys "H" (Halt processing) and "K" (Kontinue processing) - used for some scripted settings changes that require processing to be stopped
Release 6.7.4.3
handle possible corrupt header in raw data from some RPis
Release 6.7.4.4
accept the port number in the GS list - may help CG-NAT GS
prevent reverse orthomorphic projection from producing zero height or width map boundaries and therefore downloading nothing
Release 6.7.4.5
limit excessive zooming out
Release 6.7.4.6
receiver options enhancement
Release 6.7.4.7
accept BaseStation MSG format messages from dumpHFDL
Release 6.7.4.8
View..Messages shows messages from dumpHFDL - among others
Release 6.7.4.9
protect re-entrancy in Internet check
Release 6.7.5.1
accept new format of Inmarsat ephemerides
fix QNH parsing problem with USA METARs containing the keyword AUTO
Release 6.7.5.2
QNH : if nearest METAR report is > 2 hours old, search 5 next nearest reports within 100 nm
Release 6.7.5.3
add Options...Message View...Options to select what message types to display in the window (VHF ACARS, VDL2, HFDL, HF Selcal, Inmarsat) assuming you are receiving those
Release 6.7.5.4
provision to read an HF Selcal to Registration definition file into SQB field UserString3
look up Registration from HF Selcal in the SQB database and display the registration in View messages
Release 6.7.5.5
add new option to accept unpaired Mode-S positions within 5 minutes of a previous position report - this extends the coverage in marginal areas
Release 6.7.5.6
User defined Selcal UserString number (default 3)
handle 32 Selcal tones instead of original 16 tones
Release 6.7.5.7
changed Celestrak default TLE format
Release 6.7.5.8
In View.Messages, copy (= left click) and paste (= right click) to facilitate adding registrations to HF Selcals
new option "Record Mode3A/3C pings"
new window to display Mode3A/3C history graph (accelerator = 'T')
use screen centre for QNH, not outline centre, if the chart/outline is displaced
new Options..Alert..TCAS..Ignore "no data" TCAS - this fixes the A400 alert problem generally, without losing 'real' TCAS events.
Release 6.7.5.9
fix time zone error in QNH retrieval
Enjoy!
Bev
COAA
