November 25, 2026, 09:18:22 PM
SBS3 - Decoding Port 10001
Started by Martin Waller, November 05, 2012, 08:01:26 PM
Martin Waller
I'm looking at decoding data from port 10001 of the SBS-3. In particular I'd like to decode the Mode S Data Long Format packets.
I have access to the Kinetic API Reference Guide and I can see packates of type 0x05 being send by the SBS-3. Typically this data may look like:
10 02 05 00 E8 3D 3C A0 00 06 BC FB B3 45 24 7F
C4 8E 48 4C 53 10 03 B6 52
which is nicely bracketed by the DLE, STX, ..., DLE, ETX and CRC. That leaves me with the data in the middle:
C4 8E 48 4C 53
Which is a 0x05 packet - the Mode S Data - Long Format packet. The documentations suggests that this then breaks down as:
Byte 0 - Packet Type
Byte 1 - Not used
Byte 2 - 4 timestamp
Byte 5 - 18 14 bytes of Mode S Data
So the 14 bytes are:
A0 00 06 BC FB B3 45 24 7F C4 8E 48 4C 53
The last three 48 4c 53 seem to be the address code - possibly reversed.
My question is, does anyone know how to decode the rest of the packet? Is it encrypted, is it documented, can anyone provide any guidence on how to decode this please?
Many thanks
Martin
Martin Waller
Hello, many thanks to all that have read this message but I'm now sorted.
Martin
lanek
Hi Martin,
How did you end up decoding this message? I have contacted Kinetic support and asked them to provide documentation.
Lane
Quote from: lanek on January 24, 2013, 10:42:14 PM
Kinetic has published an API:
http://www.kinetic-avionics.com/newsite/api.php
lanek
Yes, I have looked at the API Document v 1.03 and all it says is this
0x01 - ADS-B or TIS-B data (KAL_PKT_MODES_ADSB)
Byte 0 - packet type
Byte 1 - not used
Byte 2-4 - Rolling timestamp - in 50ns intervals
Byte5-18 - the 14 bytes of Mode S data.
As the original post asks, what is the Mode S data? I am still yet to receive a reply from Kinetic and it has nearly been 1 week.
Quote from: lanek on January 29, 2013, 10:25:45 PM
I suspect you won't get a reply from Kinetic.  No one's heard anything from them for months.
acarslogger
Assuming the data on port 10001 is the same as the raw data output by Basestation on port 30006, then it's defined in ICAO Annex 10.
Google, or try this as a starter  http://legacy.icao.int/anb/panels/scrsp/docs/Doc.9871-E2-20110425.pdf  .
Good luck !
Stuart
lanek
Quote from: lanek on February 01, 2013, 01:35:55 AM
at a cost of $500-1000 each.
Or free in electronic format for RTCA members.
lanek
Yes, free. I was aware of that but I do not know any one with a RTCA membership.
