November 23, 2026, 12:09:43 PM
Base Station Reporter
Started by TheGreatBear, February 12, 2012, 11:26:16 PM
TheGreatBear
How long do the reports stay in BSR and can you make them indefinite?
Smudger98
I run BS create reports and save them in Excel, that way you can keep them for as long as you need them.. I dont think BS deletes anything unless directed to.. therefor the logs list should continute to get bigger..
Basestation Reporter is just a browser and editor for the Basestation.sqb database.
I've no idea if there's a maximum limit on the number of records that can be held in the SQLite database.
My sqb file has aircraft records going back to 2005.  The flight sessions attached to the aircraft record are deleted periodically using GAS' SBS Populate.
A large sqb file can slow things up a bit.
Why do you ask?
John1958
Hi all, I'm a newbie so please be gentle with me!!!!!  :-)
I use an SBS-1, and changed laptops a couple of years ago, now I'm unable to delete the spurious hexcodes which are sitting at the top of my reporter!!!  Used to use sqlite on my old one, but this newer laptop doesn't seem to like it......I've tried to download it a couple of times in case I'd done something wrong!!!!!
Can anyone offer me a solution please????
Thanks in advance
John
Hi John
Try using SQLite Expert Personal, it's free and very easy to use:
http://www.sqliteexpert.com/download.html
John1958
Hiya.....thats the one I had before!!!  Did try and re-download it today, and got the message that my free trail period was ended!!!!
Any way round this at all?
John
G4UMW
Are you sure you didn't download the Professional version? I'm sure that the Personal version does not have a time limit.
Rob/G4UMW
There's no free trial with the Personal Edition.
When you say the "laptop doesn't seem to like it", what happens?
John1958
Hiya, yup sorted now!!!!  :-(
Now when I used to click on one of the heading on my old laptop, it brought the wierd ones to the top, this doesnt, how can I get them up to delete them please?
John
Clicking any column will sort ascending/descending.  Just tried it and works as it should.
John1958
Yeah, does for me too, but doesnt bring up the spurious ones!!
09009C is right at the top on my basestation reporter, but doesnt come up when I click the top of a column!
John
The column will sort the data.  It doesn't know what's a spurious code.
John1958
Hi ANMER, seems I had a problem with my reporter, the sqb file was corrupted somehow!!! After a phone call to the VERY nice man at Kinetic,(Chris Taylor), he's got me up and running again!!! And thanks for all your help as well!!!
Now, does anyone know where I can download a new sqb file from, as I've now lost the one I had with 100,000 plus entries in it?
John
SBS-Resources had a "starter" sqb file.
http://www.sbs-resources.com/downloads/index.html
There's also one on the Kinetic site but not sure how many records it has or how old it is?
http://www.kinetic-avionics.com/newsite/resourcesdownloads.php#4
John1958
Cheers yet again ANMER......I assume yr here in the sunny UK?
I've got ADLite running, and I assume you need an internet connection to run this, or am I wrong there? Also, can I assume it will run and work anywhere in the world?
John
