September 23, 2026, 12:02:55 AM
Im Excited!
Started by BigRed, February 13, 2012, 09:28:15 AM
BigRed
Hi all,
Today after a descent wait a package from Moonraker  in the UK arrived!!!
Im now the proud owner of a Moonraker RADAR-100 Kit-10 (11-567) antenna setup!!
Sometime in the next 48 hours I hope to take down my old setup and redo everything.
As well as the Moonraker (with pre-amp) is a KAL-BS1105 going up, this Im going to have connected to my SBS3 dedicated to PP (once I get that working properly again) and the Moonraker will be dedicated to MMS2 connected to my SBS1er1.
I should also get a height gain of two / three feet, some might say 'so what!' but in my case I am located in the worse of the worse for this hobby and any gain in height is a massive increase.
The pic is my current setup.
I look forward to reporting how things go!!! IM EXCITED!  8)  8)  8)
CAM
PP - v5
MMS2 - TVL1
Smudger98
Sounds just like a kid at crimble... ;)  and why not...
BigRed
Stay tuned....
Last night we got the new 'antennas' up looks very impressive!!!!  8)
Early reports indicate a MASSIVE improvement. I hope latter today to get some more detailed info regarding this.
Now all I got to do is get PP fixed and see how the other antenna goes!
CAM
MMS2 TVL1
PP v5
BigRed
Everything is now up - and been working for 48 hours!!
Ive completely redone my antenna. So now I have the Moonraker RADAR 100Kit with pre-amp and a Kinetic BS105 5db with ground-plane antenna with no pre-amp.
The Moonraker is used for MMS2 and the BS105 for PP.
So far I am really impressed with both antennas. Even the BS105 is performing well.  :P
However, nothing for me is going to fix the fact I live in a tremendously bad area for this hobby!! I live in a suburb called Douglas in Townsville - look it up and you'll see!  ???
Stats so far:
NORTH = 120NM    an improvement of 40/50NM
EAST    = 210NM    an improvment of 100NM
SOUTH = 170NM    an improvement of 70/80NM
WEST   = 180NM    an improvement of 60/80NM
Nothing will improve my S/W approach where a significant amount of traffic comes the mountain range plus islands just cant be beat for me.
If I was able to gain another ten feet I know I would achieve another significant improvment, that isnt going to happen unfortunetly!!!!!! Maybe my next post???
Any questions of thoughts sing out.
CAM
MMS2 TVL1
PP (Mlat) v5
Chris-G0WTZ
I have a similar set up and found the pre amp under the 1105 was a big improvement but under the moonraker it was negligable
Which courier handled the Moonraker antenna? (Just curious as it is very good but a bit long to ship ecconomically
BigRed
Hi Chris,
Im thinking about puting a basic Pre-Amp on the BS1105 wait and see.
To answer your question UKMail Express and Mair then via Australian Air Express, does that help?
CAM
Chris-G0WTZ
Thanks I will get prices from our courier
MIXISM
Big Red are you seeing any upclose effects like the doughnut hole effect from that antenna?
Later
BigRed
Morning Mixism,
If you mean when a contact is overhead or very close I get a stuttering effect.... yes I do (is that what you mean), while annoying the BS1105 is filling that gap. The distance increase is far outweighing the issue.
Let me know.
CAM
Chris-G0WTZ
I would have to draw a diagram to show it properly but as the gain increases you will get more range and more donut. I have always said the BS1105 is the best all rounder and while the new Moonraker high give more range I lose some close in stuff so the BS1105 and Moonraker on a switch work well.
At the end of the day Cam you have 2 good antennas which is way better than many who only use the mag mount have fun and I look forward to your conclusions in a week or two
Chris
BigRed
Chris,
When you mention 'switch what do you mean?'
CAM
Chris-G0WTZ
I have an antenna switch so I can switch between two antennae I always compare against the BS1105 as my reference and when I have a full screen I swap antenna to see if it increases or decreases count.
I have just set my mac up to run XP and Vista at the same time so I can have two SBS's on the same machine and then I can have one on each antenna It looks odd in coherence to see 2 basestations running side by side
BigRed
Ohhhhh, now you have pricked my interest!!! 8)
I must look into getting a switch, Im using paralells too, but Im using the BS1105 purely as a standalone (SBS3) for PP and the Moonraker seperately on BS for MMS2 (SBS1er1).
A switch would be handy!!! hmmm we must talk more!
CAM
Chris-G0WTZ
MFJ-1702CN available from Andrews is probably your best option you will need some N-SMA patches etc
If you have a mac and paralells you need two installs of windows I used vista and xp as I had them both and I have the SBS-3 on vista and the SBS-1eR on xp works fine but you have to get one running before you plug the other one in or as I have it the 1er on USB and the SBS-3 on ethernet.
Email me direct if you need any help
BigRed
OK... today we placed the antenas on a new master pole ontop of the roof!! At least a fifteen feet gain!!! Which in my case is awesome!!  :)
To early to prodict but.... I can see ground traffic moving around the hard-stand magnificently well!!!   ;D
Distances for the Moonraker.... not enough aircraft up to tell at the moment.
In the next day or so I will be able to let you all know as well as photos version three!!!
CAM  :P
