November 20, 2026, 04:28:55 AM
Strange display on adsbScope
Started by GregHudson, December 05, 2012, 09:16:51 AM
GregHudson
G'Day All (and thanks to Anmer for creating this section so quickly).
I've just got my GNS 5890 up & running with my external antenna, and it's going very nicely, BUT...
adsbScope is giving me grief. What's happening, is whenever a new aircraft appears, a line shoots out from MY position, to the location of the aircraft at initial contact. After a short period, another line appears from me to the aircraft. So, I end up with lines everywhere - even after the aircraft has been dropped.
It wasn't doing this at the beginning, so I must have changed something - but I can't figure out WHAT I've changed, or where.
In the listbox to the left of the Connect button, I'm also getting the words 'Compress Track x' (x being the tracking number) for each aircraft.
I'm sure this wasn't happening before either, and I suspect they are related. I can't find any option to switch track compression on or off.
Any ideas how to fix this please anyone ?
Thanks, Greg.
(Total newbie)
Hi Greg
I haven't used adsbScope but is there a setting anywhere to draw a bearing line from your location to the selected aircraft?
GregHudson
Thanks Mike. That did the trick.
It was in 'View / Maximum Range' setting.
All it needed was a bit of lateral thinking ;-)
Regards, Greg.
