October 23, 2026, 09:40:10 AM
RF Splitters
Started by BigRed, January 02, 2013, 11:32:10 AM
BigRed
After reading Mike's pers opinion regarding the MicroADSB I noted his reference to RF Splitters.  :D
Now I love experiementing - so I looked at my own setup and thought I could do the same and why not?   :P
At the moment I am basically running two SBS3's one for PP and one for MMS2 and BS, antennas one moonraker and other a standard BS105 both are on amps.
What Ive done and its working is Ive connect both SBS3's to the Moonraker via a very basic RF splitter its messy as Ive had to use a few more plugs then I'd like and will probably have to create or order some descent patch leads hence removing some plugs.
My question as and I noticed there were different types of RF splitters is do I need to consider a better splitter? (as im sold on the idea and can remove a amp and antenna) and is the loss worth it? Id imagine this sort of hotch-potch setup would be creating a bit of loss in signal - I have noticed the blue lights flickering more in the past as I'd always have a steady two lights and now on both it clickers more.
I look forward to advice and guidance  8)
Hi Cam, Happy New Year.
I'm more than happy with my splitter.  The only drawback is the cost at just under GBP £100.
I tried using a BNC T-Piece and one receiver grabbed all the data.
kered
Would a duplexer not work? they are reasonably priced and work both ways, ie 1 to 2 or 2 to 1
Also heftally built as they are for transmit to
BigRed
Hi Mike and Kered,
Cheers on the advice - which one did you get Mike, theyre might be something similar here and Kered, duplexer?
Mike Im using a standard BNC-T seems to be working!
G4UMW
#5
Duplexers are used on two-way radio systems where there is a difference (usually of at least several MHz) between the tx and rx frequencies. They permit simultaneous transmission and reception using a single aerial i.e. duplex operation (hence the name). They're also used to isolate the receiver from the transmitter on radar systems. I don't think one would work to split a single frequency output from a single aerial to two receiver ports.
Rob/G4UMW
kered
Thanks Tom, Have you tried it, big diference in the price compared to the one Anmer has.
Quote from: kered on January 02, 2013, 06:32:37 PM
No I haven't tried it.
BigRed
OK,
Research thus far, I am now using whats called a '2-way Wilkinson and N-Way Cascaded Power Divider / Combiner' from RFI Comms. With new patch leads etc thus removing several add-on plugs. See pic.
I also have on order the same as Viking9 the 2gig splitter.
But so far it seems to work very well, the difference from using the t-piece is obvious.
BigRed
Mike,
Cost for Splitter $70 AUS and $30 for three new patch leads
And I got the item from UHF.com.au
Ive used these guys a few times plus they service and install allot of our radios at work and have always been helpful even when they dont stock what Im looking for!
Chris-G0WTZ
Do bear in mind the one Tom has found is for 75 ohm cable (TV and Sattelite) so a mismatch may give losses plus cables could be awkward as they will be F type
BigRed
Thanks Chris,
The RFI one seems to be working brilliantly, Im not seeing any loss to both PP and BS.
The Monster 2Gig I think will just be a 'testa'!
My wife is thrilled to see one antenna removed from the roof!!!  :P
birdie
#14
Quote from: Anmer on January 02, 2013, 11:55:52 AM
This is a good one made by Mini-circuit. I am using this with good results.
http://www.minicircuits.com/pdfs/ZAPD-2-21-3W.pdf
USD 54.95 each.
