November 25, 2026, 09:18:12 PM
No Sound
Started by Arno01, January 04, 2013, 08:39:49 PM
Arno01
Just got my sbs3 today, all up and running, fresh install from the SBS1E, just used sqb and ini files. Radio panel is set up and freq entered, Mixer panel states streaming and control panel has both freq as active (dancing green bars) how ever I can not here anything, sound is working ok, you tube etc. Any ideas?? Many thanks for any pointers
What are you using for sound?  Speakers via SBS3 or sound card on PC or audio streaming via VLC or QuickTime?
Arno01
Hi Mike, using the sound card on the laptop
Arno01
Just been reading, could be the power supply, with both sdr running it needs 900ma and my usb can only give 500ma. Will check more in the morning.
Thanks for mentioning Radarspotting.com  ;)
Arno01
Update, red usb is now plugged into iphone charger, still not getting any sound?
What frequencies are you tuned to?
Arno01
Tuner A is AM, 130.000 amd SDR 1 IS 132.55 and SDR 2 is 129.55 both SDR are working tuner A. Squelch is set right down
shakysen
Maybe a daft question .lead STEREO or MONO?.Reason I ask one of my Radio's would'nt work sound wise switched to stereo alls fine now
Arno01
Quote from: shakysen on January 05, 2013, 09:34:34 AM
Is that a software setting in basestation?
Have you got any powered, stand-alone speakers that you can use to test the sound from the SBS-3?
Arno01
No speakers, but just plugged headset into the back and it is working
OK, so the SBS-3 sound output is working but not when you use the MIC in port on the laptop?
Have you tried audio streaming?
Arno01
Haven't tried audio streaming. Strange thing was that the headphones were working, but just went deaf, slight hissing and freq bar was moving (ezy on the app) but no sound through the headset.
What antenna are you using for the radios?
