November 25, 2026, 12:54:12 AM
Slightly OT - Aerial Masts
Started by Mista Uzi, January 13, 2013, 03:36:44 AM
Mista Uzi
Hi all
Slightly off topic, but is related to my SBS installation.
In the next few months I will be returning to the UK and intend to upgrade my remote SBS setup.
I will be installing a 20ft swaged pole, already sourced.  At the top will be my main 1090mhz aerial.  I aim to situate a discone and a second 1090mhz aerial also on the pole, but underneath the main aerial.
I have all the bits I need except being able to source a suitable mounting bracket for the additional aerials.  Ideally what I am after is a mount between 4-6 feet long with 90 degree turns at the end.  This to mount horizontally on my main pole and the uprights allow for verticle aerial installation.
I have tried googling, but so far not found what I am looking for.
Grateful if someone knows of a good online retailer that I can contact
mista uzi
#1
Hi Mista Uzi (9mm ;D ;D )
I think you are looking for a 'crossover plate'. I found some on the Moonraker site:
http://www.moonraker.eu/Mounting-Clamps
And this forum post offers a home build solution:
http://forums.radioreference.com/scanner-receiver-antennas/183166-90-degree-antenna-bracket.html
HTH
PS
Having realised you are in Aus, maybe these guys can help:
http://www.zcg.com.au/antenna_mast_mounting_clamps.htm
