October 14, 2026, 06:27:09 PM
USB Active extension cable
Started by yarmouthshipping, February 13, 2013, 11:29:20 PM
yarmouthshipping
Hi guys i have decided to put my dongle in the loft and have read that its best to run an active repeater usb cable to the loft.
Can anyone tell me the maximum length that i should use because i will need around 10 meters.
Simon
Simon
I've never used one but this is what Maplin's website says:
This 12m Active repeater USB cable acts as a hub enabling you to daisy chain up to 5 together to get a total length of up to 60m. No longer are you restricted by the 5m length of USB cables, you can now connect a USB device up to 60m away. The active repeater is bus powered so no additional power supplies are needed as it takes it power from the actual USB port. This cable still supports the 480Mbps data speed for USB 2.0 devices and supports this across multiple cables in a daisy chain. The active repeater is also backward compatible with USB 1.1 and USB 1.0 cables. This active repeater cable has been designed with a locking function on the USB cable and the extender port to stop the cables coming loose when used in a daisy chain formation. The active repeater supports Windows operating systems Win98 and above, along with MAC OS and Linux.
http://www.maplin.co.uk/usb-2.0-12m-active-repeater-cable-444544
kered
I have a 10m one running my weather webcam, Logitech quickcam 9000, with the cable only it sometimes drops out(power loss) i cured it by putting a cheap usb powered hub on the end and plugging the camera into the end hub.
mezoo
Same here. Using a 10m active USB cable to my GNS in the loft.
Works like a charm.
